symmacros
第14楼2015/10/12
Mass Spectral Library & Search Software - Version 2014
最新的NIST 14谱库,它是在 NIST 11 基础上发展的当前最全的新谱库,它囊括了至今几乎所有的EI所产生的质谱数据,它还含有MS/MS 产生的数据,gc数据,谱库搜索软件等。它可以帮助您对质谱出来的数据有一个明确的答案。是每一台质谱必备的分析软件,它随时不断地更新和补充新的谱图。
Identify your mass spectra with the NIST 14 Mass Spectral Library and Search Software. NIST 14, the successor to NIST 11, is a collection of electron ionization (EI) mass spectra, tandem MS/MS spectra, gc data, and software for searching and identifying your mass spectra. NIST 14 is integrated with most mass spectral data systems, including Agilent ChemStation/MassHunter, Thermo Xcalibur, and others. The NIST Library is known for its high quality, broad coverage, and accessibility. It is a product of a three decade, comprehensive evaluation and expansion of the world'smost widely used and trusted mass spectral reference library compiled by a team of experienced mass spectrometrists in which each spectrum was examined for correctness.
