wang2559
第38楼2006/11/05
好像如下标准网站尚没有。
氧化钼制品ASTM A146–04 Standard Specification for Molybdenum Oxide Products
不锈钢和耐热铬镍钢板、薄板及带材ASTM A167–99 Standard Specification for Stainless and Heat-Resisting Chromium-Nickel Steel Plate, Sheet, and Strip
不锈钢和耐热铬钢板、薄板及带材ASTM A176–99 Standard Specification for Stainless and Heat-Resisting Chromium Steel Plate, Sheet, and Strip
普通锻制碳素钢管的规格ASTM A181/A181M–01 Standard Specification for Carbon Steel Forgings, for General-Purpose Piping
高温设备用锻制或轧制的合金钢管法兰、锻制管件、阀门及零件ASTM A182/A182M–04 Standard Specification for Forged or Rolled Alloy-Steel Pipe Flanges, Forged Fittings, and Valves and Parts for High-Temperature Service
钢轨用碳素钢螺栓和螺母ASTM A183–03 Standard Specification for Carbon Steel Track Bolts and Nuts
钢筋混凝土用焊接钢丝结构ASTM A185–02 Standard Specification for Steel Welded Wire Reinforcement, Plain, for Concrete
高压用无缝碳素钢锅炉管ASTM A192/A192M–02 Standard Specification for Seamless Carbon Steel Boiler Tubes for High-Pressure Service
