liuxilin1215
第11楼2016/11/25
ASTM D1062-08(R2015) Standard Test Method for Cleavage Strength of Metal-to-Metal Adhesive Bonds如有侵权,请版主及时删除!
第12楼2016/11/25
ASTM D1002-10 Standard Test Method for Apparent Shear Strength of Single-Lap-Joint Adhesively Bonded Metal Specimens by Tension Loading (Metal-to-Metal)如有侵权,请版主及时删除!
