第11楼2009/02/05
Determination of thiophanate-methyl and its metabolites at trace level in spiked natural water using the supported liquid membrane extraction and the microporous membrane liquid-liquid extraction techniques combined on-line with high-performance liquid chromatography
Sandahl M.; Mathiasson L.; Jonsson J.A.
Journal of Chromatography A, Volume 893, Number 1, 29 September 2000 , pp. 123-131(9)
http://www.ingentaconnect.com/content/els/00219673/2000/00000893/00000001/art00697
第12楼2009/02/05
Determination of Carbendazim, Thiophanate-methyl and Benomyl in Agricultural Products by HPLC
SAKAI NAOKO,et al.;
Annual Report of Tokyo Metropolitan Institute of Public Health; VOL.;NO.56;PAGE.157-160(2006)
Abstract;
A determination method of carbendazim (MBC), thiophanate-methyl (TM), and benomyl (BM) in agricultural products by using HPLC was investigated. MBC, TM and BM were extracted with methanol from homogenates of agricultural products. The methanol extract was evaporated down to ca. 70mL, and 100mL of 10% sodium chloride solution added, and defatted by n-hexane partitioning. The three compounds were extracted with ethyl acetate-n-hexane (1:1) from the aqueous layer and adjusted to pH6-7. BM was hydrolyzed to MBC while being extracted with methanol. TM in the ethyl acetate-n-hexane (1:1) extract was converted to MBC by refluxing at 120.DEG.C., for 30min with copper acetate in 50% acetic acid. For tea samples, the three compounds were cleaned up using Bond Elut PSA after refluxing with copper acetate. Total concentration of BM, TM and MBC were measured as that of MBC by HPLC. Recoveries at the 0.10.MU.g/g level were more than 70% from agricultural products except for some crops. The detection limits were 0.01.MU.g/g in all samples, except for tea where the limit was 0.05.MU.g/g. (author abst.)
http://sciencelinks.jp/j-east/article/200609/000020060906A0252442.php
