ian.cheng
第17楼2018/04/07
个人理解如下,供参考:
在标准中有以下这么一句话,个人理解应该是在stability date 前都可以同时使用新旧两个标准,而stability date 日期后就只能用新的标准了;
而不同标准的 stability date 都可以在以下官网搜索到:http://webstore.iec.ch
The committee has decided that the contents of this document will remain unchanged until the
stability date indicated on the IEC website under "http://webstore.iec.ch" in the data related to
the specific document. At this date, the document will be
• reconfirmed,
• withdrawn,
• replaced by a revised edition, or
• amended.
wooyuenkin
第19楼2018/04/08
谢谢版主,我也是对Stability date有些疑问,经你这样一说就明了了。谢谢。
