tks for u great support!
I need these ----
happyjyl 发表:玻璃漏斗 Glass funnel long stem
试管 test tube test tube brush test tube holder test tube rack
蒸发皿 evaporating dish small
烧杯 beaker
锥形瓶 Erlenmeyer
量筒 grad cylinder
洗瓶 plastic wash bottle
勺皿 casserole ,small stoppered flask
分液漏斗 separalory funnel
warter bath/oil bath
strring bar
magnetic stirrer
冷凝器 condenser
Ballast bottle
圆颈烧瓶 Round-bottom flask
试剂瓶 reagent bottles
托盘天平 platform balance 台秤
0.1g 托盘pan 指针刻度表pointer and scale
crossbeams and sliding weights 游码
分析天平 two-pan/single-pan analytical balance
滴定管 burette glass bead(basic) nozzle
移液管 pipette 胖肚 elongated glass bulb
洗耳球 rubber suction bulb
玻棒 glass rod
玻璃活塞 stopcock
容量瓶 pyknowmeter flasks
比重瓶 (one-mark)volumetric flasks
胖肚吸管 one-mark pipette
刻度吸管 graduated pipettes
锥形瓶(conical flask) 250ml×4 药匙(medicine spoon)×1
(Erlenmeyer flask) 100 ml×3 滴管(drip tube;dropper)×2
烧杯(beaker) 500 ml×1 玻棒(Glass stic)×2
250 ml×3 木试管夹(test tube clamp;test tube holder)×1
100 ml×3 胖肚吸管(straws) 25 ml×1
50 ml×2 10 ml×1
容量瓶(volumetric flask) 100 ml×2 乳钵(morta)×1
50 ml×4 洗耳球(ear washing bulb)
碘量瓶 (Iodine numoe flask; iodine flask) 500 ml×3
试剂瓶 (reagent bottle) (无色)×2
(棕色)×2 配洗液:
量筒(cylinder) 100 ml×1 K2Cr2O72g+5ml水→65mlH2SO4
(graduated cylinder)10ml×1 边加边搅拌(stir)。
铁支架(siderocradle)+蝴蝶架
白瓷板(White Porcelain Board ) (一)清点仪器(to count;to make an inventory)
酸式滴定管(Acid burette) 25 ml×1 配洗液 (Lotion)
碱式滴定管(Alkali burette)25 ml×1 一般仪器的洗涤
直型冷凝器(rectocondensor)×1 容量瓶(volumetric flask)
漏斗架 (funnel stand) ×2 移液管(pipe)
水浴锅(water bath kettle) ×1
温度计(Thermometer;hygrometer;hydroscope) ×1
电炉(electric furnace;electric hot plate;electric stove) 四人一个
分析化学:analytical chemistry
定性分析:qualitative analysis
定量分析:quantitative analysis
物理分析:physical analysis
物理化学分析:physico-chemical analysis
仪器分析法:instrumental analysis
流动注射分析法:flow injection analysis;FIA
顺序注射分析法:sequentical injection analysis;SIA
化学计量学:chemometrics
绝对误差:absolute error
相对误差:relative error
系统误差:systematic error
可定误差:determinate error
随机误差:accidental error
不可定误差:indeterminate error
准确度:accuracy
精确度:precision
偏差:debiation,d
平均偏差:average debiation
相对平均偏差:relative average debiation
标准偏差(标准差):standerd deviation;S
相对平均偏差:relatibe standard deviation;RSD
变异系数:coefficient of variation
误差传递:propagation of error
有效数字:significant figure
置信水平:confidence level
显著性水平:level of significance
合并标准偏差(组合标准差):pooled standard debiation
舍弃商:rejection quotient ;Q
滴定分析法:titrametric analysis
滴定:titration
容量分析法:volumetric analysis
化学计量点:stoichiometric point
等当点:equivalent point
电荷平衡:charge balance
电荷平衡式:charge balance equation
质量平衡:mass balance
物料平衡:material balance
质量平衡式:mass balance equation
酸碱滴定法:acid-base titrations
质子自递反应:autoprotolysis reaction
质子自递常数:autoprotolysis constant
质子条件式:proton balance equation
酸碱指示剂:acid-base indicator
指示剂常数:indicator constant
变色范围:colour change interval
混合指示剂:mixed indicator
双指示剂滴定法:double indicator titration
非水滴定法:nonaqueous titrations
质子溶剂:protonic solvent
酸性溶剂:acid solvent
碱性溶剂:basic solvent
两性溶剂:amphototeric solvent
无质子溶剂:aprotic solvent
均化效应:differentiating effect
区分性溶剂:differentiating solvent
离子化:ionization
离解:dissociation
结晶紫:crystal violet
萘酚苯甲醇: α-naphthalphenol benzyl alcohol
奎哪啶红:quinadinered
百里酚蓝:thymol blue
偶氮紫:azo violet
溴酚蓝:bromophenol blue
配位滴定法:compleximetry
乙二胺四乙酸:ethylenediamine tetraacetic acid,EDTA
螯合物:chelate compound
金属指示剂:metal lochrome indcator
氧化还原滴定法:oxidation-reduction titration
碘量法:iodimetry
溴量法:bromimetry ]
溴量法:bromine method
铈量法:cerimetry
高锰酸钾法:potassium permanganate method
条件电位:conditional potential
溴酸钾法:potassium bromate method
硫酸铈法:cerium sulphate method
偏高碘酸:metaperiodic acid
