w20030901
第55楼2006/12/06
Adobe Acrobat 7.0 Professional is very good and full function.
If you only want to read the file, I means you do not want to edit the pdf file, PDG浏览器 is a good select. It is only 606k and green.
If you want, please email me, I will upload it. But I don't know if it is possible to upload it here. Good luck!
Pdfreader
PDFreader.zip
