Ω 离子分析
第19楼2006/12/05
先发个简单些的关于全自动稀释的装置吧。全英文的,希望能有所帮助。瑞士万通的产品。
Metrohm 846 Dosing Interface - intelligent dosing
Pipetting – transferring – diluting – dosing – dispensing
The 846 Dosing Interface and the 800 Dosino turn the basic liquid handling operations into child's play. The 846 Dosing Interface is a control unit for up to four dosing elements. It can be used to expand existing Metrohm systems but also deals, as an independent system, with any liquid handling task occurring in the laboratory.
Thanks to the straightforward and unrestricted programming of the dosing elements even the most complex liquid handling tasks in the range 10 µL to 100 mL can be performed with high accuracy and precision.
Advantages of automatic versus manual liquid handling
Sample preparation needs less time
The results are independent of the operator
Reagent consumption is lower, which means less waste and less waste removal costs
Improved dosing accuracy and precision
Fully automated dosing setups can be configured
Amazing possibilities!
The 846 Dosing Interface is USB-compatible and fits perfectly into existing Titrando and automation systems, which can thus be equipped with additional dosing elements.
The 846 Dosing Interface can be controlled with an 840 Touch Control, as an independent system, or via PC. Control by PC offers two possibilities, namely tiamo™ or the PC Control software. Whatever type of control you choose, all of them are compatible with the FDA Regulation 21 CFR Part 11.
The 846 Dosing Interface is equipped with four MSB ports allowing to connect 800 Dosinos, 805 Dosimats, stirrers, etc. in the same way as this can be done with a Titrando or Sample Processor.
