PERFUME00
第14楼2018/07/04
The data that can be shared is up to this point, and the polarity column is used. (VF-WAXms) It's a friend's data. I'm sorry.
PERFUME00
第15楼2018/07/04
If the information is insufficient, we will analyze it directly and contact you again.
Thank you very much for your reply. ^^;;;;;
