Thanks to colon for sharing such good information !
I have copied the英语论文写作常用经典句子, reorganized the format and saved as Word document for easy reference. (please note that the file “英语论文写作常用经典句子 with bullet points.doc” may not be properly displayed on the screen depending on the version of Word you are using)
(By the way, I think that there may be some typing errors or mistakes in the information. For example, the sentence “This paper proceeds as follow” in the second line of the first section, which should be read as “This paper proceeds as follows”. Similar to “minutes of meeting”, there is always a “s” after “follow” and “minute”)
