liuhaowei
第53楼2007/03/30
梅特勒的好.中文操作界面.
the First level of Excellence标准型中文滴定仪
- One ClickTM Titration 一键滴定
"- Learn titration & Method editor with building block concept
学习滴定功能和搭“积木”式的灵活方法编辑方式"
"- Terminal of brilliant color Touch Screen with Chinese Manu
中文操作界面的高亮度彩色触摸屏的控制终端"
- Hot Plug & Play Hardware expansibility.即插即用的硬件扩展
" - The individual Chinise Home Screen with Short Cuts for
each user. 带图形化快捷键设置的个性化中文操作界面"
- Resolution(分辨率): 0.1 mV; 0.002 pH(pM/pX); 0.1μA
- 120 samples per series. 每个样品系列的样品数多达120个
"- Comprehensive user management system, such as enforce
password to register.全面的用户管理系统,如登录密码保护等"
"- automatic burette (with 1/20,000 steps & 0.5μL Resolution)
recognition via RFID射频识别智能滴定管,1/20,000滴定管体积"
- Memories about 120 methods. 内存可多至120个方法
"- EQP, EP, STAT, Polar (Ipol/Upol), Dead-Stop, ISE titration;
多点的等当点和终点设定滴定,恒pH/电位滴定,恒电流/恒电
压极化滴定,永停滴定和离子直接测定功能"
- Dynamic/increment titrant addition; 动态加液和增量加液方式
- EQU & fixed time measure mode;平衡控制和定时控制测量
"- Fuzzy logic to make fast and accurate measurement;
模糊逻辑控制确保快速而准确的测量"
- Built-in Mettler Application database.内置应用方法库
Standard configuration;仪器标准配置
" - Main unit with built-in burette drive, analog board,
built-in magnetic stirrer, 内置1个滴定管驱动器,1个模拟
主板接口模块和1个磁力搅拌器的主机(含2个mv/pH测量电极
接口,1个极化电极接口,1个参比电极接口,1个温度电极接口,
1个以太网接口,3个RS232接口,2个USB接口,1个现场总线接
口,3个泵/搅拌器接口,1个TTL I/O接口)."
" - Documentation including Installation Information,
Installation Instruction, Quick Guide, Memo Card,
Application Brochure中文操作说明书,中文安装指导,中
文快速入门手册,中文记忆卡,英文应用手册"
