飞花刀语
第41楼2007/02/10
+---ASTM B
| ASTM B 134B 134M-01.pdf
| ASTM B 362-91.pdf
| ASTM B 388-00.pdf
| ASTM B 389-81.pdf
| ASTM B 563-01.pdf
| ASTM B 584-04.pdf
| ASTM B 604-91.pdf
| ASTM B 770-02.pdf
| ASTM-B.pdf
| ASTM-B134.pdf
| ASTM_B563.pdf
| ASTM_B703.pdf
| ASTM_B770.pdf
| B0088-03无缝铜水管.pdf
+---ASTM C
| C1027.PDF
| C1028.PDF
| C1040.PDF
| C1042.PDF
| C1044.PDF
| C1045.PDF
| C1054.PDF
| C1100.PDF
| C1105.PDF
| C1111.PDF
| C1113.PDF
| C1114.PDF
| C1123.PDF
| C1137.PDF
| C1161.PDF
| C1167.PDF
| C1170.PDF
| C1171.PDF
| C1175.PDF
| C1176.PDF
| C1179.PDF
| C1202.PDF
| C1211.PDF
| C1218.PDF
| C1223.PDF
| C1227.PDF
| C1229.PDF
| C1231.PDF
| C836.PDF
| C837.PDF
| C844.PDF
| C845.PDF
| C848.PDF
| C849.PDF
| C856.PDF
| C878.PDF
| C881.PDF
| C884.PDF
| C885.PDF
| C888.PDF
| C900.PDF
| C901.PDF
| C928.PDF
| C930.PDF
| C935.PDF
| C936.PDF
| C937.PDF
| C938.PDF
| C939.PDF
| C953.PDF
| C956.PDF
| C965.PDF
| C973.PDF
| C974.PDF
| C975.PDF
| C980.PDF
飞花刀语
第42楼2007/02/10
+---ASTM D
| +---1
| | D1002.PDF
| | D1062.PDF
| | D1084.PDF
| | D1101.PDF
| | D1144.PDF
| | D1146.PDF
| | D1151.PDF
| | D1183.PDF
| | D1184.PDF
| | D1304.PDF
| | D1337.PDF
| | D1338.PDF
| | D1488.PDF
| | D1489.PDF
| | D1490.PDF
| | D1579.PDF
| | D1582.PDF
| | D1583.PDF
| | D1779.PDF
| | D1780.PDF
| | D1781.PDF
| | D1828.PDF
| | D1874.PDF
| | D1875.PDF
| | D1876.PDF
| | D1879.PDF
| | D1916.PDF
| | D1994.PDF
| | D1995.PDF
| | D2093.PDF
| | D2094.PDF
| | D2095.PDF
| | D2293.PDF
| | D2294.PDF
| | D2295.PDF
| | D2339.PDF
| | D2556.PDF
| | D2557.PDF
| | D2559.PDF
| | D2651.PDF
| | D2674.PDF
| | D2739.PDF
| | D2851.PDF
| | D2918.PDF
| | D2919.PDF
| | D2979.PDF
| | D3111.PDF
| | D3121.PDF
| | D3163.PDF
| | D3164.PDF
| | D3164M.PDF
| | D3165.PDF
| | D3166.PDF
| | D3167.PDF
| | D3310.PDF
| | D3433.PDF
| | D3434.PDF
| | D3482.PDF
| | D3498.PDF
| | D3528.PDF
| | D3535.PDF
| | D3632.PDF
| | D3658.PDF
| | D3762.PDF
| | D3807.PDF
| | D3808.PDF
| | D3929.PDF
| | D3930.PDF
| | D3931.PDF
| | D3933.PDF
| | D3983.PDF
| | D4027.PDF
| | D4300.PDF
| | D4317.PDF
| | D4338.PDF
| | D4339.PDF
| | D4426.PDF
| | D4497.PDF
| | D4498.PDF
| | D4499.PDF
| | D4501.PDF
| | D4502.PDF
| | D4562.PDF
| | D4680.PDF
| | D4688.PDF
| | D4689.PDF
| | D4690.PDF
| | D4783.PDF
| | D4800.PDF
| | D4896.PDF
| | D5040.PDF
| | D5041.PDF
| | D5113.PDF
| | D5215.PDF
| | D5266.PDF
| | D5267.PDF
| | D5363.PDF
| | D5572.PDF
| | D5573.PDF
| | D5574.PDF
| | D5648.PDF
| | D5649.PDF
| | D5656.PDF
| | D5657.PDF
| | D5751.PDF
| | D5824.PDF
| | D5868.PDF
| | D5999.PDF
| | D6004.PDF
| | D6005.PDF
| | D6105.PDF
| | D6195.PDF
| | D6325.PDF
| | D6396.PDF
| | D6411D64.PDF
| | D6412D64.PDF
| | D6463.PDF
| | D6464.PDF
| | D6465.PDF
| | D896.PDF
| | D897.PDF
| | D898.PDF
| | D899.PDF
| | D903.PDF
| | D904.PDF
| | D905.PDF
| | D906.PDF
| | D907.PDF
| | D950.PDF
| | R0017.PDF
飞花刀语
第43楼2007/02/10
| +---2
| | ASTM D6127-97.PDF
| | ASTM D6128-97.PDF
| | ASTM D6129-97.PDF
| | ASTM D6133-00.PDF
| | ASTM D6136-97.PDF
| | ASTM D6137-97.PDF
| | ASTM D6138-97.PDF
| | ASTM D6140-97.PDF
| | ASTM D6142-97.PDF
| | ASTM D6144-97.PDF
| | ASTM D6147-97.PDF
| | ASTM D6148-97.PDF
| | D0910-04a航空汽油技术规范.pdf
| | D0975-05柴油技术规范.pdf
| | D1152-97(2001)甲醇(甲基醇).pdf
| | D1719-05异丁醇.pdf
| | D1835-05液化石油(LP)气.pdf
| | D1836-02商品己烷.pdf
| | D2668-02红外线吸收法测定绝缘油中2,6-二叔丁基对甲酚和2,6-二叔丁基对苯酚的试验方法.pdf
| | D2880-03燃气轮机用燃料油.pdf
| | D3131-02乙酸异丙酯(99%度).pdf
| | D3734-05高闪点芳烃石脑油.pdf
| | D3735-02VM&P石油脑.pdf
| | D4150-03气体燃料及相关术语.pdf
| | D4814-02汽车火花点火发动机燃料技术规范.pdf
| | D5445-05商品贮运用图示标志的标准规定.pdf
| | D6985-04a用于军用船舶的中间馏分燃油规范.pdf
| +---3
| | D1000 – 99 Adh Tapes.pdf
| | D1002 – 01.PDF
| | D1037 – 99 Standard Test Methods for Evaluating Properties of Wood-Base Fiber and Particle Panel Materials1.pdf
| | D1062 – 96e1.PDF
| | D1084 – 97 Adh Viscosity.pdf
| | D1084 – 97.PDF
| | D1779 – 98.PDF
| | D1780 – 99.PDF
| | D1781 – 98.PDF
| | D1828 – 01.PDF
| | D1874 – 62 (Reapproved 1998).PDF
| | D1875 – 95.PDF
| | D1876 – 01.PDF
| | D1879 – 99.PDF
| | D1916 – 93 (Reapproved 1997).PDF
| | D1979 - 97 Standard Test Method for Free Formaldehyde Content of Amino Resins.PDF
| | D1994 – 95 (Reapproved 2000).PDF
| | D1995 – 92 (Reapproved 1998)e1.PDF
| | D2000 – 03.pdf
| | D2093 - 97.PDF
| | D2094 - 00.PDF
| | D2095 - 96e1.PDF
| | D2122 - 98.pdf
| | D2240 – 02b.pdf
| | D2247 – 02.pdf
| | D2293 – 96.PDF
| | D2294 – 96.PDF
| | D2295 – 96.PDF
| | D2339 – 98.PDF
| | D2464 - 99.pdf
| | D2466 – 02 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe Fittings, Schedule 40.PDF
| | D2467 – 02.pdf
| | D2513 - 04 Standard Specification for Thermoplastic Gas Pressure Pipe, Tubing, and Fittings.PDF
| | D2556 – 93a (Reapproved 1997).PDF
| | D2557 – 98.PDF
| | D2559 – 00.PDF
| | D2609 - 02 聚乙烯(PE)塑料管用塑料制插入式配件的标准规范 Standard Specification for Plastic Insert Fittings for Polyethylene (PE) Plastic Pipe.pdf
| | D2651 – 01.PDF
| | D2674 – 72 (Reapproved 1998).PDF
| | D2739– 97.PDF
| | D2851– 98.PDF
| | D2918– 99.PDF
| | D2919– 01.PDF
| | D2967 - 02a.pdf
| | D2979– 01.PDF
| | D3111 – 99 Standard Test Method for Flexibility Determination of Hot-Melt Adhesives by Mandrel Bend Test Method.pdf
| | D3121– 94 (Reapproved 1999).PDF
| | D3163– 01.PDF
| | D3164M– 98.PDF
| | D3164– 97.PDF
| | D3165– 00.PDF
| | D3166– 99.PDF
| | D3167– 97.PDF
| | D3307-06 Standard Specification for Perfluoroalkoxy (PFA)-Fluorocarbon Resin Molding and Extrusion Materials.pdf
| | D3310– 00.PDF
| | D3359–02 Standard Test Methods for Measuring Adhesion by Tape Test.pdf
| | D3426 – 97 Electric Strength.pdf
| | D3433 – 99.PDF
| | D3434 – 00.PDF
| | D3482 – 90 (Reapproved 2000).PDF
| | D3498 – 01.PDF
| | D3528 – 96.PDF
| | D3535 – 00.PDF
| | D3632 – 98.PDF
| | D3658 – 01.PDF
| | D3762 – 98.PDF
| | D3807 – 98.PDF
| | D3808 – 01.PDF
| | D3929 – 96e1.PDF
| | D3930 – 93a (Reapproved 1999)e1.PDF
| | D3931 – 93a (Reapproved 1999)e1.PDF
| | D3933 – 98.PDF
| | D3983 – 98.PDF
| | D4027 – 98.PDF
| | D4060 - 95.pdf
| | D4300 – 01.PDF
| | D4317 – 98.PDF
| | D4332 - 91 Standard practice for conditioning containers, packages, or packaging components for testing.pdf
| | D4338 – 97.PDF
| | D4339 – 01.PDF
| | D4426 – 01.PDF
| | D4497 – 94 (Reapproved 1999).PDF
| | D4498 – 00.PDF
| | D4499 – 95 (Reapproved 2000).PDF
| | D4501 – 01.PDF
| | D4502 – 92 (Reapproved 1998)e1.PDF
| | D4562 – 01.PDF
| | D4680 – 98.PDF
| | D4688 – 99.PDF
| | D4689 – 99.PDF
| | D4690 – 99.PDF
| | D4783 – 01.PDF
| | D4800 – 94 (Reapproved 1999).PDF
| | D4896 – 01.PDF
| | D4985 – 03.pdf
| | D5040 – 90 (Reapproved 1997)e1.PDF
| | D5041 – 98.PDF
| | D5113 – 97.PDF
| | D5215 – 93 (Reapproved 1999).PDF
| | D523 – 89 (Reapproved 1999).pdf
飞花刀语
第44楼2007/02/10
| | D5266 – 99.PDF
| | D5267 – 97.PDF
| | D5363 – 97.PDF
| | D5572 – 95 (Reappproved 1999).PDF
| | D5573 – 99.PDF
| | D5574 – 94 (Reapproved 1999)e1.PDF
| | D5648 – 01.PDF
| | D5649 – 01.PDF
| | D5656 – 01.PDF
| | D5657 – 01.PDF
| | D5751 – 99.PDF
| | D5824 – 98.PDF
| | D5868 – 01.PDF
| | D5952 – 02.PDF
| | D5953M – 96 (Reapproved 2001).PDF
| | D5954 – 98.PDF
| | D5955 – 02.PDF
| | D5956 – 96 (Reapproved 2001).PDF
| | D5957 – 98.PDF
| | D5958 – 99.PDF
| | D5959 – 96 (Reapproved 2003).PDF
| | D5960 – 03.PDF
| | D5961 D5961M – 01e1.PDF
| | D5962 – 96 (Reapproved 1999) Standard Guide for Maintaining Unqualified Coatings (Paints) Within Level I Areas of a Nuclear Power Facility.PDF
| | D5963 - 97a (Reapproved 2001)e1 Standard Test Method for Rubber Property—Abrasion Resistance (Rotary Drum Abrader).PDF
| | D5964 – 96 (Reapproved 2001) Standard Practice for Rubber IRM 902 and IRM 903 Replacement Oils for ASTM No. 2 and ASTM No. 3 Oils.PDF
| | D5965 – 02 Standard Test Methods for Specific Gravity of Coating Powders.PDF
| | D5966 – 02 Standard Test Method for Evaluation of Engine Oils for Roller Follower Wear in Light-Duty Diesel Engine.PDF
| | D5967 – 03 Standard Test Method for Evaluation of Diesel Engine Oils in T-8 Diesel Engine.PDF
| | D5968 – 04 Standard Test Method for Evaluation of Corrosiveness of Diesel Engine Oil at 121°C.PDF
| | D5969 – 02 Standard Test Method for Corrosion-Preventive Properties of Lubricating Greases in Presence of Dilute Synthetic Sea Water Environments.PDF
| | D5970 – 96 (Reapproved 2002) Standard Practice for Deterioration of Geotextiles from Outdoor Exposure.PDF
| | D5971 – 01 Standard Practice for Sampling Freshly Mixed Controlled Low-Strength Material.PDF
| | D5972 – 02 Standard Test Method for Freezing Point of Aviation Fuels (Automatic Phase Transition Method).PDF
| | D5973 – 97 (Reapproved 2003) Standard Specification for Elastomeric Strip Seals with Steel Locking Edge Rails Used in Expansion Joint Sealing.PDF
| | D5974 – 00 Standard Test Methods for Fatty and Rosin Acids in Tall Oil Fractionation Products by Capillary Gas Chromatography.PDF
| | D5975 – 96 (Reapproved 2004) Standard Test Method for Determining the Stability of Compost by Measuring Oxygen Consumption.PDF
| | D5976 – 00 Standard Specification for Type I Polymer Modified Asphalt Cement for Use in Pavement Construction.PDF
| | D5977 – 03 Standard Specification for High Load Rotational Spherical Bearings for Bridges and.PDF
| | D5978 – 96e1 Standard Guide for Maintenance and Rehabilitation of Ground-Water Monitoring.PDF
| | D5979 – 96 (Reapproved 2002) Standard Guide for Conceptualization and Characterization of Ground-Water Systems.PDF
| | D5980 – 96 (Reapproved 2004) Standard Guide for Selection and Documentation of Existing Wells for Use in Environmental Site Characterization and Monitoring.PDF
| | D5999 – 96 Standard Test Method for Noninterference of Adhesives in Repulping.PDF
| | D6004 – 96 Standard Test Method for Determining Adhesive Shear Strength of Carpet Adhesives.PDF
| | D6005 – 96 Standard Test Method for Determining Slump Resistance of Carpet Adhesives.PDF
| | D6040 - 06 Standard Guide to Standard Test Methods for Unsintered Polytetrafluoroethylene (PTFE) Extruded Film or Tape.pdf
| | D610 - 01.pdf
| | D6105 – 97.PDF
| | D6127 - 97.PDF
| | D6128 - 97.PDF
| | D6129 - 97.PDF
| | D6133 - 00.PDF
| | D6136 - 97.PDF
| | D6137 - 97.PDF
| | D6138 - 97.PDF
| | D6140 - 97.PDF
| | D6142 - 97.PDF
| | D6144 - 97.PDF
| | D6147 - 97.PDF
| | D6148 - 97.PDF
| | D6150 - 97.PDF
| | D6151 - 97.PDF
| | D6153 - 97.PDF
| | D6155 - 97.PDF
| | D6157 - 97.PDF
| | D6159-97.PDF
| | D6160-98.PDF
| | D6163-00.PDF
| | D6166-97.PDF
| | D6168-97.PDF
| | D6170-97-Editorial Correction 99.PDF
| | D6171-97-Editorial Correction 98.PDF
| | D6172-98-Editorial Correction 98.PDF
| | D6174-97.PDF
| | D6175-98.PDF
| | D6177-97.PDF
| | D6178-97.PDF
| | D6179-97.PDF
| | D6181-97.PDF
| | D6185-97.PDF
| | D6185-98.PDF
| | D6187-97.PDF
| | D6188-97.PDF
| | D6189-97.PDF
| | D6191-97.PDF
| | D6195 – 97.PDF
| | D6195-97.PDF
| | D6196-97.PDF
| | D6198-00.PDF
| | D6198-01.PDF
| | D6200-00.PDF
| | D6201-00.PDF
| | D6201-01.PDF
| | D6201-99.PDF
| | D6202-00a.PDF
| | D6203-97.PDF
| | D6204-99.PDF
| | D6206-97.PDF
| | D6207-97-Reapproved 2003.PDF
| | D6207-97.PDF
| | D6208-97.PDF
| | D6213-97.PDF
| | D6214-98.PDF
| | D6216-98.PDF
| | D6217-98.PDF
| | D6222-00.PDF
| | D6223-00.PDF
| | D6224-98.PDF
| | D6227-97.PDF
| | D6228-98.PDF
| | D6229-98.PDF
| | D6231-98.PDF
| | D6232-00.PDF
| | D6233-98.PDF
| | D6234-98.PDF
| | D6236-98.PDF
| | D6237-98.PDF
| | D6238-98.PDF
| | D6239-02.PDF
| | D624 – 00e1.pdf
| | D6242-98.PDF
| | D6245-98.PDF
| | D6246-01.PDF
| | D6246-98.PDF
| | D6249-98.PDF
| | D6250-98.PDF
| | D6251 D6251M - 00.PDF
| | D6252 D6252M - 98.PDF
| | D6258-98-Editorial Correction 99.PDF
| | D6261-98.PDF
| | D6262-98.PDF
| | D6263-98.PDF
| | D6264-98.PDF
| | D6265-98.PDF
| | D6268-98.PDF
| | D6269-98.PDF
| | D6270-98.PDF
| | D6271-98.PDF
| | D6272-00.PDF
| | D6273-98.PDF
| | D6275-98.PDF
| | D6277-99.PDF
| | D6278-98.PDF
| | D6279-99-Editorial Correction 00.PDF
| | D6280-98.PDF
| | D6281-98.PDF
| | D6283-98.PDF
| | D6284-98.PDF
| | D6288-98.PDF
| | D6289-98.PDF
| | D6293-98.PDF
| | D6294 – 98.PDF
| | D6295 D6295M – 98.PDF
| | D6296 – 98.PDF
| | D6297 - 98.PDF
| | D6299 - 00.PDF
| | D6300 – 02.PDF
| | D6300 – 03.PDF
飞花刀语
第45楼2007/02/10
| | D6301 – 98.PDF
| | D6302 – 98.PDF
| | D6304 – 00.PDF
| | D6304 – 03.PDF
| | D6304 – 04.PDF
| | D6305 – 02.PDF
| | D6305 – 98e1.PDF
| | D6306 – 98.PDF
| | D6311 – 98.PDF
| | D6317 – 98.PDF
| | D6318 – 98.PDF
| | D6319 – 00a.PDF
| | D6319 – 00ae1.PDF
| | D6319 – 00ae2.PDF
| | D6320 – 99.PDF
| | D6322 – 00e.PDF
| | D6323 – 98.PDF
| | D6325 – 98.PDF
| | D6326 – 98.PDF
| | D6327 – 98.PDF
| | D6329 – 98.PDF
| | D6330 – 98.PDF
| | D6333 – 98.PDF
| | D6334 – 98.PDF
| | D6335 – 03.PDF
| | D6335 – 03a.PDF
| | D6335 – 98.PDF
| | D6337 – 98.PDF
| | D6338 – 98.PDF
| | D6339 – 98.PDF
| | D6342 – 98.PDF
| | D6344 – 98.PDF
| | D6345 - 98 (Reapproved 2003).pdf
| | D6345 – 98.PDF
| | D6346 – 98.PDF
| | D6348 – 98.PDF
| | D6349 – 00.PDF
| | D6350 – 98.PDF
| | D6352 – 02.PDF
| | D6352 – 98.PDF
| | D6353 – 98.PDF
| | D6354 – 98.PDF
| | D6355 – 98.PDF
| | D6361 – 98.PDF
| | D6362 – 98.PDF
| | D6363 – 98.PDF
| | D6367 – 99.PDF
| | D6368 – 00.PDF
| | D6370 – 99.PDF
| | D6377 – 99.PDF
| | D6378 - 99.PDF
| | D638 – 01 Tensile Plastic.pdf
| | D6380 - 01.PDF
| | D6380 – 00.PDF
| | D6380 – 01.PDF
| | D6381 – 00.PDF
| | D6381 – 00a.PDF
| | D6381 – 03.PDF
| | D6381 – 03a.PDF
| | D6391 – 99.PDF
| | D6394 - 02.PDF
| | D6394 – 01.PDF
| | D6394 – 99.PDF
| | D6396 – 99.PDF
| | D6398 – 01.PDF
| | D6399 – 99a.PDF
| | D6401 - 99.PDF
| | D6402 - 99.PDF
| | D6403 - 99.PDF
| | D6404 - 99.PDF
| | D6405 - 99.PDF
| | D6406 - 99.PDF
| | D6407 - 99.PDF
| | D6408 - 99.PDF
| | D6409 - 99.PDF
| | D6410 - 99.PDF
| | D6411 D6411M – 99.PDF
| | D6412 D6412 - 99.PDF
| | D6414 - 99.PDF
| | D6416 D6416M - 99.PDF
| | D6417 - 02.PDF
| | D6417 - 99.PDF
| | D6418 - 01.PDF
| | D6418 - 03.PDF
| | D6418 - 99.PDF
| | D6419 - 99.PDF
| | D6422 - 99.PDF
| | D6425 - 99.PDF
| | D6426 - 02.PDF
| | D6426 - 99.PDF
| | D6427 - 99.PDF
| | D6433 - 99.PDF
| | D6436 - 00a.PDF
| | D6436 - 99.PDF
| | D6442 - 99.PDF
| | D6446 - 99.PDF
| | D6447 - 99.PDF
| | D6460 - 99.PDF
| | D6462 - 99.PDF
| | D6463 – 99.PDF
| | D6464 - 02.PDF
| | D6464 - 03.PDF
| | D6464 - 99.PDF
| | D6464 – 02.PDF
| | D6465 – 99.PDF
| | D6469 - 99.PDF
| | D6470 - 99.PDF
| | D6471 - 99.PDF
| | D6472 - 00.PDF
| | D6477 - 02.PDF
| | D6477 - 02a.PDF
| | D6479 - 00.PDF
| | D6481 - 99.PDF
| | D6482 - 99.PDF
| | D6483 - 99.PDF
| | D6484 D6484M - 99.PDF
| | D6486 - 99.PDF
| | D6487 - 99.PDF
| | D6495 - 99.PDF
| | D6496 - 99.PDF
| | D6497 - 99.PDF
| | D6498 - 99.PDF
| | D6499 - 00.PDF
| | D6501 - 99.PDF
| | D6502 - 99.PDF
| | D6512 - 00.PDF
| | D6514 - 00.PDF
| | D6514 - 02.PDF
| | D6518 - 00.PDF
| | D6518 - 02.PDF
| | D6518 - 02a.PDF
| | D6518 - 03.PDF
| | D6519 - 00.PDF
| | D6526 - 00.PDF
| | D6526 - 03.PDF
| | D6549 - 00.PDF
| | D6555 - 00a.PDF
| | D6556 - 00a.PDF
| | D6556 - 01.PDF
| | D6556 - 02a.PDF
| | D6557 - 00.PDF
| | D6557 - 03.PDF
| | D6558 - 00.PDF
| | D6559 - 00.PDF
| | D6571 - 00.PDF
| | D6573 D6573M - 00.PDF
| | D6577 - 00.PDF
| | D6593 - 03.PDF
| | D6594 - 00.PDF
| | D6594 - 01.PDF
| | D6594 - 03.PDF
| | D6597 – 00.pdf
| | D6600 - 00.PDF
| | D6601 - 00.PDF
| | D6602 - 02.PDF
| | D6602 - 03a.PDF
| | D6609 - 00.PDF
| | D6610 - 00.PDF
| | D6610 - 01.PDF
| | D6613 - 00.pdf
| | D6615 - 00.PDF
| | D6616 - 01.PDF
| | D6628 - 01.PDF
| | D6646 - 01.PDF
| | D6666 - 01.PDF
| | D6671 - 01.PDF
| | D6673 - 01.PDF
| | D6676 - 01.PDF
| | D6687 - 01.PDF
| | D6695 - 01.PDF
| | D6695 - 03a.PDF
| | D6709 - 03.PDF
| | D6723 - 01.PDF
| | D6732 - 01.PDF
| | D6742 D6742M - 01.PDF
| | D6743 - 01.PDF
| | D6746 – 02a.PDF
| | D6748 - 02.PDF
| | D6751 – 02.PDF
| | D6751 – 02a.PDF
| | D6751 – 03.PDF
| | D6752 – 02.PDF
| | D6752 – 02a.PDF
| | D6762 – 02e1.PDF
| | D6768 – 02.PDF
| | D6770 – 02.PDF
| | D6778 – 02.PDF
| | D6779 – 02.PDF
| | D6779 – 02a.PDF
| | D6782 – 02.PDF
| | D6783 – 02.PDF
| | D6789 – 02.PDF
| | D6792 – 02.PDF
| | D6801 – 02.PDF
| | D6812 – 02.PDF
| | D6813 – 02.PDF
| | D6815 – 02.PDF
| | D6819 – 02.PDF
| | D6819 – 02e1.PDF
| | D6824 – 02.PDF
| | D6826 – 02.PDF
| | D6833 – 02.PDF
| | D6837 – 03.PDF
| | D6838 – 02.PDF
| | D6841 – 02.PDF
| | D6842 – 02.PDF
| | D686 - 00.PDF
| | D6864 – 03.PDF
| | D6864 – 03a.PDF
| | D6864 – 03e1.PDF
| | D6883 – 03.PDF
| | D6890 – 03.PDF
| | D6890 – 03a.PDF
| | D6897 – 03.PDF
| | D6915 – 03.PDF
| | D6940 – 03.PDF
| | D6941 – 03.PDF
| | D695 - 02.pdf
| | D6962 – 03.PDF
| | D7243 - 06 Standard guide for measuring the saturated Hydraulic conductivity of paper industry sludges.pdf
| | D732 - 2002 用穿孔工具测量塑料剪切强度的标准试验方法.pdf
| | D737 - 96 Test Method for Air Permeability of Textile Fabrics.PDF
| | D785 - 2003 塑料和电绝缘材料洛氏硬度的标准试验方法.pdf
| | D785 -03 洛氏硬度.pdf
飞花刀语
第46楼2007/02/10
| | D792 -00.pdf
| | D896 – 97.PDF
| | D897 – 01.PDF
| | D898 – 96.PDF
| | D899 – 00.PDF
| | D903 – 98.PDF
| | D904 – 99.PDF
| | D905 - 98.PDF
| | D906 – 98.PDF
| | D907 – 00.PDF
| | D950 – 98.PDF
| +---4
| | ASTM D6150-97.PDF
| | ASTM D6151-97.PDF
| | ASTM D6153-97.PDF
| | ASTM D6155-97.PDF
| | ASTM D6157-97.PDF
| | ASTM D6159-97.PDF
| | ASTM D6160-98.PDF
| | ASTM D6163-00.PDF
| | ASTM D6166-97.PDF
| | ASTM D6168-97.PDF
| | ASTM D6170-97-Editorial Correction 99.PDF
| | ASTM D6171-97-Editorial Correction 98.PDF
| | ASTM D6172-98-Editorial Correction 98.PDF
| | ASTM D6174-97.PDF
| | ASTM D6175-98.PDF
| | ASTM D6177-97.PDF
| | ASTM D6178-97.PDF
| | ASTM D6179-97.PDF
| | ASTM D6181-97.PDF
| | ASTM D6185-97.PDF
| | ASTM D6185-98.PDF
| | ASTM D6187-97.PDF
| | ASTM D6188-97.PDF
| | ASTM D6189-97.PDF
| | ASTM D6191-97.PDF
| | ASTM D6195-97.PDF
| | ASTM D6196-97.PDF
| | ASTM D6198-00.PDF
| | ASTM D6198-01.PDF
| | ASTM D6200-00.PDF
| | ASTM D6201-00.PDF
| | ASTM D6201-01.PDF
| | ASTM D6201-99.PDF
| | ASTM D6202-00a.PDF
| | ASTM D6203-97.PDF
| | ASTM D6204-99.PDF
| | ASTM D6206-97.PDF
| | ASTM D6207-97-Reapproved 2003.PDF
| | ASTM D6207-97.PDF
| | ASTM D6208-97.PDF
| | ASTM D6213-97.PDF
| | ASTM D6214-98.PDF
| | ASTM D6216-98.PDF
| | ASTM D6217-98.PDF
| | ASTM D6222-00.PDF
| | ASTM D6223-00.PDF
| | ASTM D6224-98.PDF
| | ASTM D6227-97.PDF
| | ASTM D6228-98.PDF
| | ASTM D6229-98.PDF
| | ASTM D6231-98.PDF
| | ASTM D6232-00.PDF
| | ASTM D6233-98.PDF
| | ASTM D6234-98.PDF
| | ASTM D6236-98.PDF
| | ASTM D6237-98.PDF
| | ASTM D6238-98.PDF
| | ASTM D6239-02.PDF
| | ASTM D6242-98.PDF
| | ASTM D6245-98.PDF
| | ASTM D6246-01.PDF
| | ASTM D6246-98.PDF
| | ASTM D6249-98.PDF
| | ASTM D6250-98.PDF
| | ASTM D6251D6251M-00.PDF
| | ASTM D6252D6252M-98.PDF
| | ASTM D6258-98-Editorial Correction 99.PDF
| | ASTM D6261-98.PDF
| | ASTM D6262-98.PDF
| | ASTM D6263-98.PDF
| | ASTM D6264-98.PDF
| | ASTM D6265-98.PDF
| | ASTM D6268-98.PDF
| | ASTM D6269-98.PDF
| | ASTM D6270-98.PDF
| | ASTM D6271-98.PDF
| | ASTM D6272-00.PDF
| | ASTM D6273-98.PDF
| | ASTM D6275-98.PDF
| | ASTM D6277-99.PDF
| | ASTM D6278-98.PDF
| | ASTM D6279-99-Editorial Correction 00.PDF
| | ASTM D6280-98.PDF
| | ASTM D6281-98.PDF
| | ASTM D6283-98.PDF
| | ASTM D6284-98.PDF
| | ASTM D6288-98.PDF
| | ASTM D6289-98.PDF
| | ASTM D6293-98.PDF
| | ASTM D6297-98.PDF
| | ASTM D6299-00.PDF
| | ASTM D6378-99.PDF
| | ASTM D6380-01.PDF
| | ASTM D6394-02.PDF
| | ASTM D6401-99.PDF
| | ASTM D6402-99.PDF
| | ASTM D6403-99.PDF
| | ASTM D6404-99.PDF
| | ASTM D6405-99.PDF
| | ASTM D6406-99.PDF
| | ASTM D6407-99.PDF
| | ASTM D6408-99.PDF
| | ASTM D6409-99.PDF
| | ASTM D6410-99.PDF
| | ASTM D6414-99.PDF
| | ASTM D6416D6416M-99.PDF
| | ASTM D6417-02.PDF
| | ASTM D6417-99.PDF
| | ASTM D6418-01.PDF
| | ASTM D6418-03.PDF
| | ASTM D6418-99.PDF
| | ASTM D6419-99.PDF
| | ASTM D6422-99.PDF
| | ASTM D6425-99.PDF
| | ASTM D6426-02.PDF
| | ASTM D6426-99.PDF
| | ASTM D6427-99.PDF
| | ASTM D6433-99.PDF
| | ASTM D6436-00a.PDF
| | ASTM D6436-99.PDF
| | ASTM D6442-99.PDF
| | ASTM D6446-99.PDF
| | ASTM D6447-99.PDF
| | ASTM D6460-99.PDF
| | ASTM D6462-99.PDF
| | ASTM D6464-02.PDF
| | ASTM D6464-03.PDF
| | ASTM D6464-99.PDF
| | ASTM D6469-99.PDF
| | ASTM D6470-99.PDF
| | ASTM D6471-99.PDF
| | ASTM D6472-00.PDF
| | ASTM D6477-02.PDF
| | ASTM D6477-02a.PDF
| | ASTM D6479-00.PDF
| | ASTM D6481-99.PDF
| | ASTM D6482-99.PDF
| | ASTM D6483-99.PDF
| | ASTM D6484D6484M-99.PDF
| | ASTM D6486-99.PDF
| | ASTM D6487-99.PDF
| | ASTM D6495-99.PDF
| | ASTM D6496-99.PDF
| | ASTM D6497-99.PDF
| | ASTM D6498-99.PDF
| | ASTM D6499-00.PDF
| | ASTM D6501-99.PDF
| | ASTM D6502-99.PDF
| | ASTM D6512-00.PDF
| | ASTM D6514-00.PDF
| | ASTM D6514-02.PDF
| | ASTM D6518-00.PDF
| | ASTM D6518-02.PDF
| | ASTM D6518-02a.PDF
| | ASTM D6518-03.PDF
| | ASTM D6519-00.PDF
| | ASTM D6526-00.PDF
| | ASTM D6526-03.PDF
| | ASTM D6549-00.PDF
| | ASTM D6555-00a.PDF
| | ASTM D6556-00a.PDF
| | ASTM D6556-01.PDF
| | ASTM D6556-02.PDF
| | ASTM D6556-02a.PDF
| | ASTM D6557-00.PDF
| | ASTM D6557-03.PDF
| | ASTM D6558-00.PDF
| | ASTM D6559-00.PDF
| | ASTM D6571-00.PDF
| | ASTM D6573D6573M-00.PDF
| | ASTM D6577-00.PDF
| | ASTM D6593-00.PDF
| | ASTM D6593-02.PDF
| | ASTM D6593-02a.PDF
| | ASTM D6593-03.PDF
| | ASTM D6594-00.PDF
| | ASTM D6594-01.PDF
| | ASTM D6594-03.PDF
| | ASTM D6600-00.PDF
| | ASTM D6601-00.PDF
| | ASTM D6602-02.PDF
| | ASTM D686-00.PDF
| | D 6380 – 00.PDF
| | D 6380 – 01.PDF
| | D 6381 – 00.PDF
| | D 6381 – 00a.PDF
| | D 6381 – 03.PDF
| | D 6381 – 03a.PDF
| | D 6391 – 99.PDF
| | D 6398 – 01.PDF
| | D 6399 – 99a.PDF
飞花刀语
第47楼2007/02/10
| +---5
| | ASTM D6602-03.PDF
| | ASTM D6602-03a.PDF
| | ASTM D6609-00.PDF
| | ASTM D6610-00.PDF
| | ASTM D6610-01.PDF
| | ASTM D6613-00.pdf
| | ASTM D6615-00.PDF
| | ASTM D6616-01.PDF
| | ASTM D6628-01.PDF
| | ASTM D6646-01.PDF
| | ASTM D6666-01.PDF
| | ASTM D6671-01.PDF
| | ASTM D6673-01.PDF
| | ASTM D6676-01.PDF
| | ASTM D6687-01.PDF
| | ASTM D6695-01.PDF
| | ASTM D6695-03.PDF
| | ASTM D6695-03a.PDF
| | ASTM D6709-01.PDF
| | ASTM D6709-03.PDF
| | ASTM D6723-01.PDF
| | ASTM D6732-01.PDF
| | ASTM D6742-D6742M-01.PDF
| | ASTM D6743-01.PDF
| | ASTM D6748-02.PDF
| | ASTM D6784-02产生于煤燃烧固定源的废气中元素,氧化,颗粒结合和总的水银的测试方法.pdf
| | ASTM E180-99.PDF
| | ASTM E253-01.PDF
| | ASTM E291-96.PDF
| | ASTM E334-96.PDF
| | ASTM E336-97.PDF
| | ASTM E338-84-reapproved 96.PDF
| | ASTM E338-91-Reapproved 1997.PDF
| | ASTM E4-01.PDF
| | ASTM E4-02.PDF
| | ASTM E74-00a.PDF
飞花刀语
第48楼2007/02/10
| | ASTM D6839.pdf
| | D1015.PDF
| | D1016.PDF
| | D1018.PDF
| | D1025.PDF
| | D1091.PDF
| | D1092.PDF
| | D1093.PDF
| | D1094.PDF
| | D1157.PDF
| | D1159.PDF
| | D1160.PDF
| | D1217.PDF
| | D1218.PDF
| | D1250.PDF
| | D1263.PDF
| | D1264.PDF
| | D1265.PDF
| | D1266.PDF
| | D1267.PDF
| | D127.PDF
| | D128.PDF
| | D129.PDF
| | D1298.PDF
| | D130.PDF
| | D1318.PDF
| | D1319.PDF
| | D1321.PDF
| | D1322.PDF
| | D1367.PDF
| | D1401.PDF
| | D1403.PDF
| | D1404.PDF
| | D1405.PDF
| | D1465.PDF
| | D1478.PDF
| | D1480.PDF
| | D1481.PDF
| | D1500.PDF
| | D1550.PDF
| | D1552.PDF
| | D156.PDF
| | D1655.PDF
| | D1662.PDF
| | D1740.PDF
| | D1742.PDF
| | D1743.PDF
| | D1747.PDF
| | D1748.PDF
| | D1796.PDF
| | D1831.PDF
| | D1832.PDF
| | D1833.PDF
| | D1834.PDF
| | D1835.PDF
| | D1837.PDF
| | D1838.PDF
| | D1839.PDF
| | D1840.PDF
| | D187.PDF
| | D189.PDF
| | D2001.PDF
| | D2007.PDF
| | D2008.PDF
| | D2068.PDF
| | D2069.PDF
| | D2070.PDF
| | D2156.PDF
| | D2157.PDF
| | D2158.PDF
| | D2161.PDF
| | D2162.PDF
| | D2163.PDF
| | D3231.PDF
| | D3233.PDF
| | D3234.PDF
| | D3235.PDF
| | D3236.PDF
| | D3237.PDF
| | D3238.PDF
| | D3239.PDF
| | D3240.PDF
| | D3241.PDF
| | D3242.PDF
| | D3244.PDF
| | D3245.PDF
| | D3246.PDF
| | D3336.PDF
| | D3337.PDF
| | D3338.PDF
| | D3339.PDF
| | D3340.PDF
| | D3341.PDF
| | D3342.PDF
| | D3343.PDF
| | D3344.PDF
| | D3348.PDF
| | D3427.PDF
| | D3429.PDF
| | D3461.PDF
| | D3519.PDF
| | D3520.PDF
| | D3521.PDF
| | D3522.PDF
| | D3523.PDF
| | D3524.PDF
| | D3525.PDF
| | D3527.PDF
| | D3601.PDF
| | D3603.PDF
| | D3605.PDF
| | D3606.PDF
| | D3607.PDF
| | D3699.PDF
| | D3700.PDF
| | D3701.PDF
| | D3702.PDF
| | D3703.PDF
| | D3704.PDF
| | D3705.PDF
| | D3706.PDF
| | D3707.PDF
| | D3708.PDF
| | D3709.PDF
| | D3710.PDF
| | D3711.PDF
| | D3712.PDF
| | D3764.PDF
| | D3825.PDF
| | D3827.PDF
| | D3828.PDF
| | D3829.PDF
| | D3831.PDF
| | D3944.PDF
| | D3946.PDF
| | D3948.PDF
| | D4006.PDF
| | D4007.PDF
| | D4042.PDF
| | D4045.PDF
| | D4046.PDF
| | D4047.PDF
| | D4048.PDF
| | D4049.PDF
| | D4051.PDF
| | D4052.PDF
| | D4053.PDF
| | D4054.PDF
| | D4055.PDF
| | D4056.PDF
| | D4057.PDF
| | D4072.PDF
| | D4170.PDF
| | D4171.PDF
| | D4172.PDF
| | D4174.PDF
| | D4175.PDF
| | D4176.PDF
| | D4177.PDF
| | D4178.PDF
| | D4241.PDF
| | D4248.PDF
| | D4289.PDF
| | D4290.PDF
| | D4291.PDF
| | D4292.PDF
| | D4293.PDF
| | D4294.PDF
| | D4296.PDF
| | D4304.PDF
| | D4305.PDF
| | D4306.PDF
| | D4307.PDF
| | D4308.PDF
| | D4310.PDF
| | D4312.PDF
| | D4377.PDF
| | D4378.PDF
| | D4418.PDF
| | D4419.PDF
| | D4420.PDF
| | D4421.PDF
| | D4422.PDF
| | D4423.PDF
| | D4424.PDF
| | D4425.PDF
| | D4485.PDF
| | D4486.PDF
| | D4529.PDF
| | D4530.PDF
| | D4539.PDF
| | D4616.PDF
| | D4624.PDF
| | D4625.PDF
| | D4626.PDF
| | D4627.PDF
| | D4628.PDF
| | D4629.PDF
| | D4636.PDF
| | D4682.PDF
| | D4683.PDF
| | D4684.PDF
| | D4693.PDF
| | D4715.PDF
| | D4737.PDF
| | D4739.PDF
| | D4740.PDF
| | D4741.PDF
| | D4742.PDF
| | D4746.PDF
| | D4806.PDF
| | D4807.PDF
| | D4808.PDF
| | D4809.PDF
| | D4814.PDF
| | D4815.PDF
| | D4857.PDF
| | D4858.PDF
| | D4859.PDF
| | D4860.PDF
| | D4863.PDF
| | D4864.PDF
| | D4865.PDF
| | D4868.PDF
| | D4870.PDF
| | D4871.PDF
| | D4892.PDF
| | D4893.PDF
| | D4898.PDF
| | D4927.PDF
| | D4928.PDF
| | D4929.PDF
| | D4930.PDF
| | D4931.PDF
| | D4950.PDF
| | D4951.PDF
| | D4952.PDF
| | D4953.PDF
| | D4998.PDF
飞花刀语
第49楼2007/02/10
| | D5000.PDF
| | D5001.PDF
| | D5002.PDF
| | D5003.PDF
| | D5004.PDF
| | D5006.PDF
| | D5018.PDF
| | D5056.PDF
| | D5059.PDF
| | D5119.PDF
| | D5133.PDF
| | D5134.PDF
| | D5182.PDF
| | D5183.PDF
| | D5184.PDF
| | D5185.PDF
| | D5186.PDF
| | D5187.PDF
| | D5188.PDF
| | D5190.PDF
| | D5191.PDF
| | D5234.PDF
| | D5236.PDF
| | D5273.PDF
| | D5274.PDF
| | D5275.PDF
| | D5291.PDF
| | D5292.PDF
| | D5293.PDF
| | D5302.PDF
| | D5303.PDF
| | D5304.PDF
| | D5305.PDF
| | D5306.PDF
| | D5307.PDF
| | D5372.PDF
| | D5384.PDF
| | D5441.PDF
| | D5442.PDF
| | D5443.PDF
| | D5452.PDF
| | D5453.PDF
| | D5480.PDF
| | D5481.PDF
| | D5482.PDF
| | D5483.PDF
| | D5500.PDF
| | D5501.PDF
| | D5502.PDF
| | D5533.PDF
| | D5534.PDF
| | D5579.PDF
| | D5580.PDF
| | D5598.PDF
| | D5599.PDF
| | D5600.PDF
| | D5619.PDF
| | D5620.PDF
| | D5621.PDF
| | D5622.PDF
| | D5623.PDF
| | D5662.PDF
| | D5704.PDF
| | D5705.PDF
| | D5706.PDF
| | D5707.PDF
| | D5708.PDF
| | D5709.PDF
| | D5760.PDF
| | D5761.PDF
| | D5762.PDF
| | D5763.PDF
| | D5769.PDF
| | D5770.PDF
| | D5771.PDF
| | D5772.PDF
| | D5773.PDF
| | D5797.PDF
| | D5798.PDF
| | D5799.PDF
| | D5800.PDF
| | D5842.PDF
| | D5844.PDF
| | D5845.PDF
| | D5846.PDF
| | D5853.PDF
| | D5854.PDF
| | D5862.PDF
| | D5863.PDF
| | D5864.PDF
| | D5901.PDF
| | D5949.PDF
| | D5950.PDF
| | D5966.PDF
| | D5967.PDF
| | D5968.PDF
| | D5969.PDF
| | D5972.PDF
| | D5983.PDF
| | D5984.PDF
| | D5985.PDF
| | D5986.PDF
| | D6006.PDF
| | D6021.PDF
| | D6022.PDF
| | D6045.PDF
| | D6046.PDF
| | D6074.PDF
| | D6078.PDF
| | D6079.PDF
| | D6080.PDF
| | D6081.PDF
| | D6082.PDF
| | D6120.PDF
| | D6121.PDF
| | D6122.PDF
| | D6138.PDF
| | D6139.PDF
| | D6158.PDF
| | D6159.PDF
| | D6160.PDF
| | D6184.PDF
| | D6185.PDF
| | D6186.PDF
| | D6200.PDF
| | D6201.PDF
| | D6202.PDF
| | D6203.PDF
| | D6217.PDF
| | D6224.PDF
| | D6227.PDF
| | D6258.PDF
| | D6259.PDF
| | D6277.PDF
| | D6278.PDF
| | D6293.PDF
| | D6296.PDF
| | D6299.PDF
| | D6300.PDF
| | D6304.PDF
| | D6334.PDF
| | D6335.PDF
| | D6351.PDF
| | D6352.PDF
| | D6353.PDF
| | D6354.PDF
| | D6371.PDF
| | D6374.PDF
| | D6375.PDF
| | D6376.PDF
| | D6377.PDF
| | D6378.PDF
| | D6379.PDF
| | D6384.PDF
| | D6417.PDF
| | D6421.PDF
| | D6422.PDF
| | D6423.PDF
| | D6424.PDF
| | D6425.PDF
| | D6426.PDF
| | D6439.PDF
| | D6443.PDF
| | D6445.PDF
| | D6446.PDF
| | D6447.PDF
| | D6448.PDF
| | D6450.PDF
| | D6468.PDF
| | D6469.PDF
| | D6470.PDF
| | D6481.PDF
| | D6482.PDF
| | D6483.PDF
| | D6514.PDF
| | D6546.PDF
| | D6547.PDF
| | D6549.PDF
| | D6550.PDF
| | D6553.PDF
| | D6557.PDF
| | D6558.PDF
| | D6559.PDF
| | D6560.PDF
| | D6584.PDF
| | D6591.PDF
飞花刀语
第50楼2007/02/10
| \---PDF UOP
| UOP1.pdf
| UOP114.pdf
| UOP144-88.pdf
| UOP163.pdf
| UOP172.pdf
| UOP174.pdf
| UOP197.pdf
| UOP202.pdf
| UOP209.pdf
| UOP210.pdf
| UOP211.pdf
| UOP212-03.pdf
| UOP212-77.pdf
| UOP212.pdf
| UOP248.pdf
| UOP254.pdf
| UOP262.pdf
| UOP269.pdf
| UOP274.pdf
| UOP275-98.pdf
| UOP276.pdf
| UOP286.pdf
| UOP291.pdf
| UOP294.pdf
| UOP296-82.pdf
| UOP300.pdf
| UOP303.pdf
| UOP304.pdf
| UOP311-92.pdf
| UOP311.pdf
| UOP313.pdf
| UOP314.pdf
| UOP315.pdf
| UOP317.pdf
| UOP320.pdf
| UOP326.pdf
| UOP33.pdf
| UOP333.pdf
| UOP344.pdf
| UOP350-82.pdf
| UOP357-80.pdf
| UOP358.pdf
| UOP364.pdf
| UOP373.pdf
| UOP374.pdf
| UOP375.pdf
| UOP377.pdf
| UOP379.pdf
| UOP381.pdf
| UOP382.pdf
| UOP384.pdf
| UOP387.pdf
| UOP389-86.pdf
| UOP389.pdf
| UOP391.pdf
| UOP394-85.pdf
| UOP395.pdf
| UOP405.pdf
| UOP41.pdf
| UOP410.pdf
| UOP411.pdf
| UOP412-87.pdf
| UOP413.pdf
| UOP422.pdf
| UOP423.pdf
| UOP425.pdf
| UOP430-70T.pdf
| UOP432-65T.pdf
| UOP434.pdf
| UOP436.pdf
| UOP437.pdf
| UOP438.pdf
| UOP456.pdf
| UOP46.pdf
| UOP464.pdf
| UOP481.pdf
| UOP495-00.pdf
| UOP495.pdf
| UOP496-63T.pdf
| UOP501-83.pdf
| UOP501.pdf
| UOP515.pdf
| UOP516.pdf
| UOP523.pdf
| UOP537.pdf
| UOP539.pdf
| UOP542-88.pdf
| UOP543.pdf
| UOP547.pdf
| UOP549.pdf
| UOP551.pdf
| UOP555.pdf
| UOP563.pdf
| UOP565-92.pdf
| UOP565.pdf
| UOP569.pdf
| UOP578-84.pdf
| UOP578.pdf
| UOP586.pdf
| UOP587.pdf
| UOP588.pdf
| UOP592.pdf
| UOP6.pdf
| UOP602.pdf
| UOP603.pdf
| UOP606-78.pdf
| UOP614-80.pdf
| UOP614.pdf
| UOP619.pdf
| UOP621.pdf
| UOP624.pdf
| UOP627-85.pdf
| UOP629.pdf
| UOP649.pdf
| UOP666-82.pdf
| UOP670.pdf
| UOP672.pdf
| UOP673.pdf
| UOP676.pdf
| UOP678.pdf
| UOP682.pdf
| UOP683.pdf
| UOP688.pdf
| UOP690.pdf
| UOP699.pdf
| UOP700.pdf
| UOP702.pdf
| UOP703.pdf
| UOP704.pdf
| UOP709-70.pdf
| UOP714.pdf
| UOP715.pdf
| UOP720.pdf
| UOP725.pdf
| UOP727-72.pdf
| UOP729.pdf
| UOP731.pdf
| UOP735.pdf
| UOP740.pdf
| UOP741.pdf
| UOP742.pdf
| UOP743.pdf
| UOP744-98.pdf
| UOP744.pdf
| UOP755.pdf
| UOP759.pdf
| UOP762.pdf
| UOP766.pdf
| UOP77.pdf
| UOP772.pdf
| UOP777-77.pdf
| UOP778.pdf
| UOP779.pdf
| UOP780.pdf
| UOP787.pdf
| UOP79.pdf
| UOP791.pdf
| UOP792.pdf
| UOP793.pdf
| UOP798.pdf
| UOP800.pdf
| UOP801.pdf
| UOP802.pdf
| UOP803.pdf
| UOP804.pdf
| UOP806.pdf
| UOP808.pdf
| UOP809.pdf
| UOP810.pdf
| UOP815.pdf
| UOP816.pdf
| UOP818.pdf
| UOP821.pdf
| UOP822.pdf
| UOP823.pdf
| UOP824.pdf
| UOP825.pdf
| UOP826.pdf
| UOP827.pdf
| UOP828.pdf
| UOP829.pdf
| UOP832.pdf
| UOP833.pdf
| UOP834.pdf
| UOP835.pdf
| UOP836.pdf
| UOP841.pdf
| UOP842.pdf
| UOP845.pdf
| UOP846.pdf
| UOP847.pdf
| UOP848.pdf
| UOP851.pdf
| UOP854.pdf
| UOP856.pdf
| UOP863.pdf
| UOP864.pdf
| UOP865.pdf
| UOP866.pdf
| UOP868.pdf
| UOP870.pdf
| UOP873.pdf
| UOP874.pdf
| UOP876.pdf
| UOP878.pdf
| UOP879.pdf
| UOP880.pdf
| UOP883-95.pdf
| UOP887.pdf
| UOP888-88.pdf
| UOP894.pdf
| UOP896.pdf
| UOP899-97.pdf
| UOP899.pdf
| UOP9.pdf
| UOP905.pdf
| UOP909-98.pdf
| UOP912.pdf
| UOP913.pdf
| UOP914.pdf
| UOP915.pdf
| UOP916.pdf
| UOP917.pdf
| UOP918.pdf
| UOP923.pdf
| UOP924.pdf
| UOP925.pdf
| UOP926.pdf
| UOP927.pdf
| UOP931.pdf
| UOP933.pdf
| UOP934.pdf
| UOP935.pdf
| UOP936.pdf
| UOP938.pdf
| UOP939.pdf
| UOP944.pdf
| UOP945.pdf
| UOP946.pdf
| UOP947.pdf
| UOP948.pdf
| UOP952.pdf
| UOP953.pdf
| UOP954.pdf
| UOP958.pdf
| UOP959.pdf
| UOP961.pdf
| UOP962.pdf
| UOP963.pdf
| UOP964.pdf
| UOP967.pdf
| UOP968.pdf
| UOP969.pdf
| UOP971.pdf
| UOP972.pdf
| UOP973.pdf
| UOP975-01.pdf
| UOP975.pdf
| UOP976.pdf
| UOP979.pdf
| UOP980.pdf
| UOP983.pdf
| UOP99.pdf
| UOP999-97.pdf
| UOP999.pdf
