flyheart
第11楼2007/03/06
E215-98 Standard Practice for Standardizing Equipment for Electromagnetic Examination of Seamless Aluminum-Alloy Tube
flyheart
第12楼2007/03/06
E242-95(Reapproved 2000) Standard Reference Radiographs for Appearances of Radiographic Images as Certain Parameters Are Changed
E242-95 Standard Reference Radiographs for Appearances of Radiographic Images as Certain Parameters Are Changed
flyheart
第13楼2007/03/06
E243-97 Standard Practice for Electromagnetic (Eddy-Current) Examination of Copper and Copper-Alloy Tubes
flyheart
第14楼2007/03/06
E272-99 Standard Reference Radiographs for High-Strength Copper-Base and Nickel-Copper Alloy Castings
flyheart
第15楼2007/03/06
E273-93 Standard Practice for Ultrasonic Examination of the Weld Zone of Welded Pipe and Tubing
flyheart
第16楼2007/03/06
E280-98 Standard Reference Radiographs for Heavy-Walled (41/2 to 12-in. [114 to 305-mm]) Steel Castings
E280-98 Standard Reference Radiographs for Heavy-Walled 41/2 to 12-in. 114 to 305-mm Steel Castings
