做牛做马
第11楼2007/03/15
A899-91(2002) Standard Specification for Steel Wire, Epoxy-Coated
A900/A900M-01(2006) Standard Test Method for Lamination Factor of Amorphous Magnetic Strip
A901-03 Standard Specification for Amorphous Magnetic Core Alloys, Semi-Processed Types
A902-06a Standard Terminology Relating to Metallic Coated Steel Products
A903/A903M-99(2003) Standard Specification for Steel Castings, Surface Acceptance Standards, Magnetic Particle and Liquid Penetrant Inspection
A904-04 Standard Specification for 50 Nickel-50 Iron Powder Metallurgy (P/M) Soft Magnetic Parts
A905-04 Standard Specification for Steel Wire, Pressure Vessel Winding
A906/A906M-02 Standard Specification for Grade 80 and Grade 100 Alloy Steel Chain Slings for Overhead Lifting
A908-03 Standard Specification for Stainless Steel Needle Tubing
A909/A909M-06 Standard Specification for Steel Forgings, Microalloy, for General Industrial Use
A910/A910M-05 Standard Specification for Uncoated, Weldless, 2- and 3-Wire Steel Strand for Prestressed Concrete
A911/A911M-05 Standard Specification for Uncoated, Stress-Relieved Steel Bars for Prestressed Concrete Ties
A912/A912M-04 Standard Test Method for Alternating-Current Magnetic Properties of Amorphous Materials at Power Frequencies Using Wattmeter-Ammeter-Voltmeter Method with Toroidal Specimens
A913/A913M-04 Standard Specification for High-Strength Low-Alloy Steel Shapes of Structural Quality, Produced by Quenching and Self-Tempering Process (QST)
A914/A914M-92(2005) Standard Specification for Steel Bars Subject to Restricted End-Quench Hardenability Requirements
A915/A915M-93(2003) Standard Specification for Steel Castings, Carbon, and Alloy, Chemical Requirements Similar to Standard Wrought Grades
A917-06a Standard Specification for Steel Sheet, Coated by the Electrolytic Process for Applications Requiring Designation of the Coating Mass on Each Surface (General Requirements)
A918-06 Standard Specification for Steel Sheet, Zinc-Nickel Alloy Coated by the Electrolytic Process for Applications Requiring Designation of the Coating Mass on Each Surface
A920/A920M-02a Standard Specification for Steel Bars, Microalloy, Hot-Wrought, Special Quality, Mechanical Properties
A921/A921M-93(2005) Standard Specification for Steel Bars, Microalloy, Hot-Wrought, Special Quality, for Subsequent Hot Forging
A922-05 Standard Specification for Silicon Metal
A923-06 Standard Test Methods for Detecting Detrimental Intermetallic Phase in Duplex Austenitic/Ferritic Stainless Steels
A924/A924M-07 Standard Specification for General Requirements for Steel Sheet, Metallic-Coated by the Hot-Dip Process
A925-03 Standard Specification for Zinc-5% Aluminum-Mischmetal Alloy-Coated Steel Overhead Ground Wire Strand
A926-03 Standard Test Method for Comparing the Abrasion Resistance of Coating Materials for Corrugated Metal Pipe
A927/A927M-04 Standard Test Method for Alternating-Current Magnetic Properties of Toroidal Core Specimens Using the Voltmeter-Ammeter-Wattmeter Method
A928/A928M-05 Standard Specification for Ferritic/Austenitic (Duplex) Stainless Steel Pipe Electric Fusion Welded with Addition of Filler Metal
A929/A929M-01 Standard Specification for Steel Sheet, Metallic-Coated by the Hot-Dip Process for Corrugated Steel Pipe
A930-03 Standard Practice for Life-Cycle Cost Analysis of Corrugated Metal Pipe Used for Culverts, Storm Sewers, and Other Buried Conduits
A931-96(2002) Standard Test Method for Tension Testing of Wire Ropes and Strand
A932/A932M-01(2006) Standard Test Method for Alternating-Current Magnetic Properties of Amorphous Materials at Power Frequencies Using Wattmeter-Ammeter-Voltmeter Method with Sheet Specimens
A933/A933M-95(2001) Standard Specification for Vinyl (PVC) Coated Steel Wire and Welded Wire Fabric for Reinforcement
A934/A934M-04 Standard Specification for Epoxy-Coated Prefabricated Steel Reinforcing Bars
A937/A937M-06 Standard Test Method for Determining Interlaminar Resistance of Insulating Coatings Using Two Adjacent Test Surfaces
A938-04 Standard Test Method for Torsion Testing of Wire
A939-96(2006) Standard Test Method for Ultrasonic Examination from Bored Surfaces of Cylindrical Forgings
A940/A940M-06 Standard Specification for Vacuum Treated Steel Forgings, Alloy, Differentially Heat Treated, for Turbine Rotors
A941-06a Terminology Relating to Steel, Stainless Steel, Related Alloys, and Ferroalloys
A942-95(2001) Standard Specification for Centrifugally Cast White Iron/Gray Iron Dual Metal Abrasion- Resistant Roll Shells
做牛做马
第12楼2007/03/15
A943/A943M-01(2005) Standard Specification for Spray-Formed Seamless Austenitic Stainless Steel Pipes
A944-05 Standard Test Method for Comparing Bond Strength of Steel Reinforcing Bars to Concrete Using Beam-End Specimens
A945/A945M-06e1 Standard Specification for High-Strength Low-Alloy Structural Steel Plate with Low Carbon and Restricted Sulfur for Improved Weldability, Formability, and Toughness
A946-95(2004) Standard Specification for Chromium, Chromium-Nickel and Silicon Alloy Steel Plate, Sheet, and Strip for Corrosion and Heat Resisting Service
A947M-95(2004) Standard Specification for Textured Stainless Steel Sheet [Metric]
A949/A949M-01(2005) Standard Specification for Spray-Formed Seamless Ferritic/Austenitic Stainless Steel Pipe
A950/A950M-99(2003) Standard Specification for Fusion Bonded Epoxy-Coated Structural Steel H-Piles and Sheet Piling
A951/A951M-06 Standard Specification for Steel Wire for Masonry Joint Reinforcement
A952/A952M-02 Standard Specification for Forged Grade 80 and Grade 100 Steel Lifting Components and Welded Attachment Links
A955/A955M-06a Standard Specification for Deformed and Plain Stainless-Steel Bars for Concrete Reinforcement
A956-06 Standard Test Method for Leeb Hardness Testing of Steel Products
A957/A957M-06 Standard Specification for Investment Castings, Steel and Alloy, Common Requirements, for General Industrial Use
A958-00(2006) Standard Specification for Steel Castings, Carbon and Alloy, with Tensile Requirements, Chemical Requirements Similar to Standard Wrought Grades
A959-04 Standard Guide for Specifying Harmonized Standard Grade Compositions for Wrought Stainless Steels
A960/A960M-07 Standard Specification for Common Requirements for Wrought Steel Piping Fittings
A961/A961M-07 Standard Specification for Common Requirements for Steel Flanges, Forged Fittings, Valves, and Parts for Piping Applications
A962/A962M-07 Standard Specification for Common Requirements for Steel Fasteners or Fastener Materials, or Both, Intended for Use at Any Temperature from Cryogenic to the Creep Range
A964/A964M-03 Standard Specification for Corrugated Steel Box Culverts
A965/A965M-06a Standard Specification for Steel Forgings, Austenitic, for Pressure and High Temperature Parts
A966/A966M-96(2006) Standard Test Method for Magnetic Particle Examination of Steel Forgings Using Alternating Current
A967-05 Standard Specification for Chemical Passivation Treatments for Stainless Steel Parts
A968/A968M-96(2001) Standard Specification for Chromium, Chromium-Nickel, and Silicon Alloy Steel Bars and Shapes for Corrosion and Heat-Resisting Service
A970/A970M-06 Standard Specification for Headed Steel Bars for Concrete Reinforcement
A971/A971M-05 Standard Test Method for Measuring Edge Taper and Crown of Flat-Rolled Electrical Steel Coils
A972/A972M-00(2004) Standard Specification for Fusion Bonded Epoxy-Coated Pipe Piles
A973/A973M-01 Standard Specification for Grade 100 Alloy Steel Chain
A974-97(2003) Standard Specification for Welded Wire Fabric Gabions and Gabion Mattresses (Metallic Coated or Polyvinyl Chloride (PVC) Coated)
A975-97(2003) Standard Specification for Double-Twisted Hexagonal Mesh Gabions and Revet Mattresses (Metallic-Coated Steel Wire or Metallic-Coated Steel Wire With Poly(Vinyl Chloride) (PVC) Coating)
A976-03 Standard Classification of Insulating Coatings by Composition, Relative Insulating Ability and Application
A977/A977M-02 Standard Test Method for Magnetic Properties of High-Coercivity Permanent Magnet Materials Using Hysteresigraphs
A978/A978M-97(2002)e1 Standard Specification for Composite Ribbed Steel Pipe, Precoated and Polyethylene Lined for Gravity Flow Sanitary Sewers, Storm Sewers, and Other Special Applications
A979/A979M-03 Standard Specification for Concrete Pavements and Linings Installed in Corrugated Steel Structures in the Field
A980-97(2003) Standard Specification for Steel, Sheet, Carbon, Ultra High Strength Cold Rolled
A981-97(2002) Standard Test Method for Evaluating Bond Strength for 15.2 mm (0.6 in.) Diameter Prestressing Steel Strand, Grade 270, Uncoated, Used in Prestressed Ground Anchors
A982/A982M-05 Standard Specification for Steel Forgings, Stainless, for Compressor and Turbine Airfoils
A983/A983M-06 Standard Specification for Continuous Grain Flow Forged Carbon and Alloy Steel Crankshafts for Medium Speed Diesel Engines
A984/A984M-03 Standard Specification for Steel Line Pipe, Black, Plain-End, Electric-Resistance-Welded
A985/A985M-04a Standard Specification for Steel Investment Castings General Requirements, for Pressure-Containing Parts
A986/A986M-01(2006) Standard Specification for Magnetic Particle Examination of Continuous Grain Flow Crankshaft Forgings
做牛做马
第13楼2007/03/15
A987-05 Standard Test Method for Measuring Shape Characteristics of Tin Mill Products
A988/A988M-05 Standard Specification for Hot Isostatically-Pressed Stainless Steel Flanges, Fittings, Valves, and Parts for High Temperature Service
A989/A989M-05 Standard Specification for Hot Isostatically-Pressed Alloy Steel Flanges, Fittings, Valves, and Parts for High Temperature Service
A990-06 Standard Specification for Castings, Iron-Nickel-Chromium and Nickel Alloys, Specially Controlled for Pressure Retaining Parts for Corrosive Service
A991/A991M-98(2004) Standard Test Method for Conducting Temperature Uniformity Surveys of Furnaces Used to Heat Treat Steel Products
A992/A992M-06a Standard Specification for Structural Steel Shapes
A994-05 Standard Guide for Editorial Procedures and Form of Product Specifications for Steel, Stainless Steel, and Related Alloys
A995/A995M-98(2003) Standard Specification for Castings, Austenitic-Ferritic (Duplex) Stainless Steel, for Pressure-Containing Parts
A996/A996M-06a Standard Specification for Rail-Steel and Axle-Steel Deformed Bars for Concrete Reinforcement
A997-98(2003)e1 Standard Practice for Investment Castings, Surface Acceptance Standards, Visual Examination
A998/A998M-98(2003) Standard Practice for Structural Design of Reinforcements for Fittings in Factory—Made Corrugated Steel Pipe for Sewers and Other Applications
A999/A999M-04a Standard Specification for General Requirements for Alloy and Stainless Steel Pipe
A1000-05 Standard Specification for Steel Wire, Carbon and Alloy Specialty Spring Quality
A1001-01(2006) Standard Specification for High Strength Steel Castings in Heavy Sections
A1002-99(2003) Standard Specification for Castings, Nickel-Aluminum Ordered Alloy
A1003/A1003M-05 Standard Specification for Steel Sheet, Carbon, Metallic- and Nonmetallic-Coated for Cold-Formed Framing Members
A1004/A1004M-99(2004) Standard Practice for Establishing Conformance to the Minimum Expected Corrosion Characteristics of Metallic, Painted-Metallic, and Nonmetallic-Coated Steel Sheet Intended for Use as Cold Formed Framing Members
A1005/A1005M-00(2004) Standard Specification for Steel Line Pipe, Black, Plain End, Longitudinal and Helical Seam, Double Submerged-Arc Welded
A1006/A1006M-00(2004) Standard Specification for Steel Line Pipe, Black, Plain End, Laser Beam Welded
A1007-02 Standard Specification for Carbon Steel Wire for Wire Rope
A1008/A1008M-07 Standard Specification for Steel, Sheet, Cold-Rolled, Carbon, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, Solution Hardened, and Bake Hardenable
A1009-05 Standard Specification for Soft Magnetic MnZn Ferrite Core Materials for High Frequency (10 kHz-1 MHz) Power Transformer and Filter Inductor Applications
A1010/A1010M-01e1 Standard Specification for Higher-Strength Martensitic Stainless Steel Plate, Sheet , and Strip
A1011/A1011M-06b Standard Specification for Steel, Sheet and Strip, Hot-Rolled, Carbon, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, and Ultra-High Strength
A1012-02 Standard Specification for Seamless and Welded Ferritic, Austenitic and Duplex Alloy Steel Condenser and Heat Exchanger Tubes With Integral Fins
A1013-00(2005) Standard Test Method for High-Frequency (10 kHz-1 MHz) Core Loss of Soft Magnetic Core Components at Controlled Temperatures Using the Voltmeter-Ammeter-Wattmeter Method
A1014/A1014M-06 Standard Specification for Precipitation-Hardening Bolting Material (UNS N07718) for High Temperature Service
A1015-01(2005) Standard Guide for Videoborescoping of Tubular Products for Sanitary Applications
A1016/A1016M-04a Standard Specification for General Requirements for Ferritic Alloy Steel, Austenitic Alloy Steel, and Stainless Steel Tubes
A1017/A1017M-06 Standard Specification for Pressure Vessel Plates, Alloy Steel, Chromium-Molybdenum-Tungsten
A1018/A1018M-06c Standard Specification for Steel, Sheet and Strip, Heavy-Thickness Coils, Hot-Rolled, Carbon, Commercial, Drawing, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, and Ultra-High Strength Steel
A1019/A1019M-01 Standard Specification for Closed Rib Steel Pipe with Diameter of 36 in. [900 mm] or Less, Polymer Precoated for Sewers and Drains
做牛做马
第14楼2007/03/15
A1020/A1020M-02 Standard Specification for Steel Tubes, Carbon and Carbon Manganese, Fusion Welded, for Boiler, Superheater, Heat Exchanger and Condenser Applications
A1021/A1021M-05 Standard Specification for Martensitic Stainless Steel Forgings and Forging Stock for High-Temperature Service
A1022/A1022M-06 Standard Specification for Deformed and Plain Stainless Steel Wire and Welded Wire for Concrete Reinforcement
A1023/A1023M-02 Standard Specification for Stranded Carbon Steel Wire Ropes for General Purposes
A1024/A1024M-02 Standard Specification for Steel Line Pipe, Black, Plain-End, Seamless
A1025-05 Standard Specification for Ferroalloys, General Requirements
A1026-03 Standard Specification for Alloy Steel Structural Shapes for Use in Building Framing
A1028-03 Standard Specification for Stainless Steel Bars for Compressor and Turbine Airfoils
A1030/A1030M-05 Standard Practice for Measuring Flatness Characteristics of Steel Sheet Products
A1031-05 Standard Specification for Steel, Sheet and Strip, Heavy-Thickness Coils, Alloy, Drawing Steel and Structural Steel, Hot-Rolled
A1032-04 Standard Test Method for Hydrogen Embrittlement Resistance for Steel Wire Hard Drawn Used for Prestressing Concrete Pipe
A1033-04 Standard Practice for Quantitative Measurement and Reporting of Hypoeutectoid Carbon and Low-Alloy Steel Phase Transformations
A1034/A1034M-05b Standard Test Methods for Testing Mechanical Splices for Steel Reinforcing Bars
A1035/A1035M-06 Standard Specification for Deformed and Plain, Low-carbon, Chromium, Steel Bars for Concrete Reinforcement
A1036-04 Standard Guide for Measuring Power Frequency Magnetic Properties of Flat-Rolled Electrical Steels Using Small Single Sheet Testers
A1037/A1037M-05 Standard Specification for Steel Line Pipe, Black, Furnace-butt-Welded
A1038-05 Standard Practice for Portable Hardness Testing by the Ultrasonic Contact Impedance Method
A1039/A1039M-04 Standard Specification for Steel, Sheet, Hot Rolled, Carbon, Commercial and Structural, Produced by the Twin-Roll Casting Process
A1040-06 Standard Guide for Specifying Harmonized Standard Grade Compositions for Wrought Carbon, Low-Alloy, and Alloy Steels
A1041/A1041M-04 Standard Specification for Pressure Vessel Plates, Alloy Steel, Higher Strength Chromium-Molybdenum-Tungsten
A1042/A1042M-04 Standard Specification for Composite Corrugated Steel Pipe for Sewers and Drains
A1043/A1043M-05 Standard Specification for Structural Steel with Low Yield to Tensile Ratio for Use in Buildings
A1044/A1044M-05 Standard Specification for Steel Stud Assemblies for Shear Reinforcement of Concrete
A1045-05 Standard Specification for Flexible Poly (Vinyl Chloride) (PVC) Gaskets used in Connection of Water Closets to Sanitary Drainage System
A1046/A1046M-06 Standard Specification for Steel Sheet, Zinc-Aluminum-Magnesium Alloy-Coated by the Hot-Dip Process
A1047/A1047M-05 Standard Test Method for Pneumatic Leak Testing of Tubing
A1048/A1048M-06 Standard Specification for Pressure Vessel Forgings, Alloy Steel, Higher Strength Chromium-Molybdenum-Tungsten for Elevated Temperature Service
A1049/A1049M-06 Standard Specification for Stainless Steel Forgings, Ferritic/Austenitic (Duplex), for Pressure Vessels and Related Components
A1053/A1053M-06 Standard Specification for Welded Ferritic-Martensitic Stainless Steel Pipe
