第34楼2004/11/13
联系方式:shenxp@ysweb.com
以下天平想转让.Laboratory AX205 Lab balance 0.01mg
£5,869.13 inc VAT
£4,995.00 exc VAT
The METTLER TOLEDO AX is an innovative analytical balance, which sets new world standards for weighing performance, user friendliness and quality standards. The AX has the highest resolution of any analytical balance in existence: an unmatched 50 million digits. A brilliant touch screen display, intelligent user guidance, and hands-free infrared draft shield control make this highly-precise balance faster, easier and more fun to use than ever before.
Specifications
Maximum Capacity 220 g
Readability 0.01 mg
Taring range 0...220 g
Repeatability 0.015...0.03 mg
Linearity ± 0.03...0.1 mg
Stabilization time (typical) 8...12s
Adjustment with internal weights proFACT, fully automatic time- and temperature-controlled adjustment
Adjustment with external weights custom weights
Linearization automatic linearization with each internal adjustment
Sensitivity (temperature Sampling pump drift) ± 1.0 ppm/°C
Sensitivity (long-term stability) ± 0.0001%
Interfaces RS-232C
Size of weighing pan 80x80 mm
Free height above weighing pan 240 mm
Dimensions 241x505x293 mm (WxDxH)
