醉卧古隆中
第21楼2007/07/20
Understanding the factors that govern the deposition and morphology of thin films of ZnO from aqueous solution
Journal of Materials Chemistry, 2004, 14, 2575 - 2591
Kuveshni Govender, David S. Boyle, Peter B. Kenway and Paul O'Brien
JMaterChem14-2575
醉卧古隆中
第22楼2007/07/20
Growth conditions for wurtzite zinc oxide films in aqueous solutions
Journal of Materials Chemistry, 2002, 12, 3773 - 3778
Satoshi Yamabi and Hiroaki Imai
JMaterChem12-3773
醉卧古隆中
第23楼2007/07/20
Three-Dimensional Array of Highly Oriented Crystalline ZnO Microtubes
Vayssieres, L.; Keis, K.; Hagfeldt, A.; Lindquist, S.-E.
Chemistry of Materials, 2001, 13(12), 4395-4398
ChemMater13-4395
醉卧古隆中
第24楼2007/07/20
General Route to Vertical ZnO Nanowire Arrays Using Textured ZnO Seeds
Lori E. Greene, Matt Law, Dawud H. Tan, Max Montano, Josh Goldberger, Gabor Somorjai, and Peidong Yang
Nano Letters, 2005, 5(7) pp 1231 - 1236
杨培东&NanoLett5-1231
Supporting Information
醉卧古隆中
第25楼2007/07/20
Directed Spatial Organization of Zinc Oxide Nanorods
Hsu, J. W. P.; Tian, Z. R.; Simmons, N. C.; Matzke, C. M.; Voigt, J. A.; Liu, J.
Nano Letters, 2005, 5(1), 83-86
NanoLett5-83
醉卧古隆中
第26楼2007/07/20
Purpose-Built Anisotropic Metal Oxide Material: 3D Highly Oriented Microrod Array of ZnO
Vayssieres, L.; Keis, K.; Lindquist, S.-E.; Hagfeldt, A.
Journal of Physical Chemistry B, 2001, 105(17), 3350-3352
JPhysChemB105-3350
醉卧古隆中
第27楼2007/07/20
Growth of Arrayed Nanorods and Nanowires of ZnO from Aqueous Solutions
L. Vayssieres
Advanced Materials, Volume 15, Issue 5, Pages 464-466 (March, 2003)
AdvMater15-464
醉卧古隆中
第28楼2007/07/21
Growth of well-defined ZnO microparticles by hydroxide ion hydrolysis of zinc salts
Journal of Materials Chemistry, 2003, 13, 1196 - 1201
Ruth A. McBride, John M. Kelly and Declan E. McCormack
JMaterChem13-1196
补充材料1
补充材料2
醉卧古隆中
第29楼2007/07/21
Organic Molecule-Assisted Hydrothermal Self-Assembly of Size-Controlled Tubular ZnO Nanostructures
Shen, L.; Bao, N.; Yanagisawa, K.; Domen, K.; Grimes, C. A.; Gupta, A.
Journal of Physical Chemistry C, 2007, 111(20); 7280-7287
JPhysChemC111-7280
醉卧古隆中
第30楼2007/07/21
Synthesis of Tower-like ZnO Structures and Visible Photoluminescence Origins of Varied-Shaped ZnO Nanostructures
Wang, F.; Cao, L.; Pan, A.; Liu, R.; Wang, X.; Zhu, X.; Wang, S.; Zou, B.
Journal of Physical Chemistry C, 2007, 111(21); 7655-7660
JPhysChemC111-7655
