zhanglexi
第11楼2007/08/20
我看到王中林在J.Phys.Chem.B 2003 107 8275-8280上一幅Cu纳米线的高分辨,说上面的条纹是摩尔条纹,我记起曾作出过类似的东西,感觉也应该是,所以上论坛求助。
A high-resolution TEM analysis of the Cu nanowires is
presented in Figure 9. The Morie fringes created by the double diffraction between two grains along the electron beam are visible at the bottom right corner.
