资料下载Lysine is an essential amino acid which means that it cannot be synthesized in the body at a sufficient rate to meet the physiological needs of the body, and therefore must be supplied by the diet. Lysine is one of the most important essential amino acids: it is a building block of protein and an important component in amino acid balance. It is a limiting amino acid in cereal grains and in some vegetable protein sources, therefore requiring synthetic supplementing to meet the animals needs. Lysine is a structural element of proteins; it is a vital component of the enzymes and is present in almost all the tissues of the animal. Because lysine is involved in a large number of metabolic processes it has a fundamental role in animal nutrition and animal health. Improvement in animal performance through better amino acid balance, better carcass quality, and prevention of lysine deficiency are some of the benefits associated with the right lysine content in the animal diet. For example, for piglets and pigs the use of synthetic lysine allows an increase in feed consumption and body weight gain; and an improvement in feed conversion and in nitrogen retention. Particularly with pigs, its use allows an improvement of the carcass quality. Using the Biochrom 30 buffer system, lysine can be accurately quantified in less than 10 minutes to enable adjustments to the formulation of feedstuff.
微库仑法测定废水中的可吸附有机卤素(AOX)和纸浆中的总有机卤素(TOX)
简介:纸浆和纸品工艺过程中用到高浓度的化学物,如氯,二氧化氯和盐酸用来漂白,由此产生的废水包含有机氯化物,这些物质对环境有害,因此废水中可吸附有机卤素AOX和纸浆中的总有机卤素TOX显得尤为重要。
应用指南第一篇:从等温吸附线中可以获得什么信息?
简介:比表面和孔径测量: Microtrac MRB采用气体吸附法为粉体样品的比表面值,BET值和孔径测量提供了吸附系列的分析仪器。开发和生产以及装配地点位于日本大阪的表面分析中心。 我们为客户提供先进的技术,以不断获得可靠的结果。创新和质量是我们成功的基础。
应用指南3:通过BET方法分析活性炭的比表面积(I型等温吸脱附曲线)
R1_No.2_ENG_TheevaluationoftheSpecificsurfaceareaofporousSilicabyBETmethod
R1_No.3_ENG_TheevaluationoftheSpecificsurfaceareaofactivecarbon(TypeIadsorptionisotherm)byBETmethod
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
