资料下载Christensen T., Gooden D. M., Kung J. E., and Toone E. J. (2003) Additivity and the physical basis of multivalency effects: a thermodynamic investigation of the calcium EDTA interaction. J Am Chem Soc 125, 7357-7366. Abstract: To better understand the origin of multivalency effects in ligand binding, the binding of a series of mono-, bi-, tri- and tetravalent carboxylate ligands to Ca(II) was examined by isothermal titration calorimetry (ITC). The data are inconsistent with an entropic origin of enhanced affinity, but rather show that at least in this instance the multivalency effect is enthalpic in origin. Analysis of binding data using the Jencks model shows the addition of incremental carboxylate "ligands" produces an unfavorable interaction entropy that is more than offset by a strongly favorable interaction enthalpy. The most likely source of this interaction enthalpy is the relief of repulsive Coulombic interactions in the unbound state. The conformational entropy penalty arising from the restriction of flexible dihedrals is negligible, within experimental error. On the other hand, an enthalpic contribution from linker restriction contributes strongly to the overall thermodynamics of ligand binding. Together, these data suggest that enthalpic effects dominate ligand binding, and design strategies should seek to optimize these interactions. The incorporation of unfavorable interactions in the unbound ligand that are relieved during binding provides an important mechanism by which to enhance ligand affinities.
微库仑法测定废水中的可吸附有机卤素(AOX)和纸浆中的总有机卤素(TOX)
简介:纸浆和纸品工艺过程中用到高浓度的化学物,如氯,二氧化氯和盐酸用来漂白,由此产生的废水包含有机氯化物,这些物质对环境有害,因此废水中可吸附有机卤素AOX和纸浆中的总有机卤素TOX显得尤为重要。
应用指南第一篇:从等温吸附线中可以获得什么信息?
简介:比表面和孔径测量: Microtrac MRB采用气体吸附法为粉体样品的比表面值,BET值和孔径测量提供了吸附系列的分析仪器。开发和生产以及装配地点位于日本大阪的表面分析中心。 我们为客户提供先进的技术,以不断获得可靠的结果。创新和质量是我们成功的基础。
应用指南3:通过BET方法分析活性炭的比表面积(I型等温吸脱附曲线)
R1_No.2_ENG_TheevaluationoftheSpecificsurfaceareaofporousSilicabyBETmethod
R1_No.3_ENG_TheevaluationoftheSpecificsurfaceareaofactivecarbon(TypeIadsorptionisotherm)byBETmethod
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
