方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Lysine is an essential amino acid which means that it cannot be synthesized in the body at a sufficient rate to meet the physiological needs of the body, and therefore must be supplied by the diet. Lysine is one of the most important essential amino acids: it is a building block of protein and an important component in amino acid balance. It is a limiting amino acid in cereal grains and in some vegetable protein sources, therefore requiring synthetic supplementing to meet the animals needs. Lysine is a structural element of proteins; it is a vital component of the enzymes and is present in almost all the tissues of the animal. Because lysine is involved in a large number of metabolic processes it has a fundamental role in animal nutrition and animal health. Improvement in animal performance through better amino acid balance, better carcass quality, and prevention of lysine deficiency are some of the benefits associated with the right lysine content in the animal diet. For example, for piglets and pigs the use of synthetic lysine allows an increase in feed consumption and body weight gain; and an improvement in feed conversion and in nitrogen retention. Particularly with pigs, its use allows an improvement of the carcass quality. Using the Biochrom 30 buffer system, lysine can be accurately quantified in less than 10 minutes to enable adjustments to the formulation of feedstuff.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
