方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Water activity is defined as the current volume and availability of “free” water in a sample and should not be directly compared with the water content (g water/ g substance). The water activity is given as the aw – value and ranges between 0 (absolute dryness) and 1 (condensed humidity). Only this component takes an active part in the exchange with the ambient humidity and can possibly form the ideal medium for microbiological growth on the surface which influences the microbiological stability. The water activity also has an important effect on the chemical reactions in food.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
