方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Light has properties that can be used for determining particle size and particle size distributions. In the case of diffraction instruments, such as the Microtrac S3500, the angle at which the light is diffracted depends upon the wavelength of the light and the particle size. The angle of diffraction is measured to determine size. For a particular particle size, should the wavelength change, the angle will change. There is another feature of light that can be used for determining the particle size – it is the frequency. Frequency is a measure of how many waves pass through a given point during one second. The more waves that cross the point or the closer the distance between the waves, the higher the frequency. Frequency change or shift information is used in Dynamic Light Scattering.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
