方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Reaction calorimetry is becoming more and more important, because the time from development to a marketable commodity needs to be shorter and shorter. Even at the beginning of the development process the procedure and safety has to be optimized. For this calorimetric data is needed. Depending on the system (with or without coolerbalance calorimetry) we deliver: * Reactor and cooler: power and heat curves * Accumulated heat after partial dosage * Adiabatic temperature increase through total heat or through * Accumulated heat at any time for reactor & cooler terms * Diagram of the kinetics for your reaction * At last also polymerization, crystallization and fermentation with higher accuracy
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
