资料下载The specific heat capacity was measured with step-scan differential scanning calorimetry for linear alkanes from pentane sC5H12d to nonadecane sC19H40d, for several cyclic alkanes, for linear and cyclic polyethylenes, and for a linear and a cyclic polystyrene. For the linear alkanes, the specific heat capacity in the equilibrium liquid state decreases as chain length increases; above a carbon number N of 10 sdecaned the specific heat asymptotes to a constant value. For the cyclic alkanes, the heat capacity in the equilibrium liquid state is lower than that of the corresponding linear chains and increases with increasing chain length. At high enough molecular weights, the heat capacities of cyclic and linear molecules are expected to be equal, and this is found to be the case for the polyethylenes and polystyrenes studied. In addition, the thermal properties of the solid-liquid and the solid-solid transitions are examined for the linear and cyclic alkanes; solid-solid transitions are observed only in the odd-numbered alkanes. The thermal expansion coefficients and the specific volumes of the linear and cyclic alkanes are also calculated from literature data and compared with the trends in the specific heats.
珀金埃尔默石化行业解决方案合集
简介:1955 年,由珀金埃尔默自主开发的全球首台气相色谱仪(GC)154 型气相分离仪问世。自首台GC以来,珀金埃尔默色谱技术不断迭代更新,为全球客户先后提供了近50种不同型号的仪器设备。珀金埃尔默在气相色谱领域拥众多技术创新,Clarus GC,Clarus SQ8 GCMS, TurbomatrixTM顶空自动进样器,TurbomatrixTM自动热脱附仪等持续为石油化工、环境监测、医药卫生、生物化学领域在提供最先进的解决方案。
QSight400 LC/MS/MS样本资料
简介:随着食品安全、药品安全和环境监测等领域的法规要求越来越严格,实验室将面临着诸多严峻的挑战,如更低的检出限要求、更高的检测通量和更苛刻的时效性要求等。 QSight®三重四极杆 LC/MS/MS系列产品一直以稳定和可靠的性能而著称,现推出更高灵敏度,更佳性能的QSight质谱新产品:QSight400系列质谱仪。与整体解决方案相结合,使实验室获得更高灵敏度和检测通量,从容应对更为严峻的检测挑战。 QSight 400系列质谱仪,配有高效率的双离子源,自清洁的质谱接口、专利的层流离子传输以及直观易用的操作软件。
仪器假期存放,保养及再开机注意事项
简介:为了避免春节期间,未对仪器长时间闲置做好充分准备而导致开工后仪器故障,我们特地为大家准备了《仪器假期存放、保养及再开机的注意事项》手册,让您的假期无后顾之忧。 免费下载获取该手册吧!
多光谱组织成像分析技术 在皮肤疾病研究中的应用
简介:主要介绍组织原位多标记分析技术、组织原位多标智能分析定量技术、组织原位多标记智能定量分析技术相关解决方案,以及多色标记方案的优势对比。
高分辨单细胞ICP-MS技术应用
简介:第五届原子光谱大会上珀金埃尔默东区产品经理朱敏带来的题为“高分辨单细胞ICP-MS技术应用”的报告,他介绍了PerkinElmer 公司极力倡导的单颗粒、单细胞ICP-MS(single particle-ICPMS)技术被公认为一种定性和定量测定含有特定元素的低浓度的单颗粒最有前途的方法。相对传统的元素监测方法,SP-ICP-MS技术可快速有效并提供更多的信息:它能够测定颗粒尺寸分布、颗粒个数,颗粒内部元素的浓度、颗粒外部溶解出来的元素浓度等,而且能够区分含有不同元素的特定粒子。本次报告重点介绍了单颗粒、单细胞ICP-MS技术的工作原理及典型应用
珀金埃尔默热重-红外-气相色谱质谱联用 TG-IR-GC/MS
Avio® 550 Max 珀金埃尔默高性能电感耦合 等离子体发射光谱仪
Avio 550/560 珀金埃尔默高性能电感耦合 等离子体发射光谱仪
珀金埃尔默 PerkinElmer GCMS 2400系统
珀金埃尔默GC 2400™ 平台-带分体式触摸屏 气相色谱质谱平台
珀金埃尔默 PerkinElmer MPS 320™ 微波消解仪
LAMBDA365+ 珀金埃尔默紫外/可见光谱仪
珀金埃尔默 PerkinElmer LC 300 HPLC 超高效液相
珀金埃尔默Spectrum 3™傅立叶变换红外光谱仪
珀金埃尔默 PerkinElmer PinAAcle D 900 原子吸收光谱仪
珀金埃尔默 NexION 5000 多重四极杆ICP-MS
珀金埃尔默环境监测走航系统方案
OilPrep 8 油品稀释器
OilPrep 4 油品稀释器
LPC 500液体颗粒计数器和ICP-OES油品联用系统
