方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 |
给出了催化剂中贵金属的分析。样品用硫酸或者王水消解后,用火焰AAS进行分析。 ABSTRACT A flame atomic absorption spectrometric method is described for the determination of platinum, palladium, and rhodium in used and fresh alumina- supported and sieve catalysts. A lanthanum solution was used to eliminate chemical matrix interferences. Samples were completely dissolved in sulfuric acid and aqua regia. Overall, the method has resulted in % RSD values ranging from 1.1–5.7, 2.2–5.9, and 4.8–5.3 for Pt, Pd, and Rh, respectively; the 3s detection limits were 5 µg/L Pt, 3 µg/L Pd, and 40 µg/L Rh.
珀金埃尔默热重-红外-气相色谱质谱联用 TG-IR-GC/MS
Avio® 550 Max 珀金埃尔默高性能电感耦合 等离子体发射光谱仪
Avio 550/560 珀金埃尔默高性能电感耦合 等离子体发射光谱仪
珀金埃尔默 PerkinElmer GCMS 2400系统
珀金埃尔默GC 2400™ 平台-带分体式触摸屏 气相色谱质谱平台
珀金埃尔默 PerkinElmer MPS 320™ 微波消解仪
LAMBDA365+ 珀金埃尔默紫外/可见光谱仪
珀金埃尔默 PerkinElmer LC 300 HPLC 超高效液相
珀金埃尔默Spectrum 3™傅立叶变换红外光谱仪
珀金埃尔默 PerkinElmer PinAAcle D 900 原子吸收光谱仪
珀金埃尔默 NexION 5000 多重四极杆ICP-MS
珀金埃尔默环境监测走航系统方案
OilPrep 8 油品稀释器
OilPrep 4 油品稀释器
LPC 500液体颗粒计数器和ICP-OES油品联用系统
