肝病毒会导致慢性肝炎,甚至发展为癌症。针对丙肝病毒的疫苗尚未研发成功,而类病毒颗粒(Virus-Like Particle)是疫苗发开的路线之一。在这篇文献中,澳洲的研究者使用Cypher ES原子力显微镜,对四类丙肝类病毒颗粒进行了形貌表征和纳米力学测量。
扫描在缓冲液中进行。Cypher ES的封闭样品腔可以避免溶液的挥发,保持缓冲液的离子浓度、pH、以及温度恒定。类病毒颗粒的尺寸小于200nm,表面富含柔软的脂质。Cypher ES具有高分辨扫描能力以及精确的力控制,可以对类病毒颗粒进行准确、无损的表征。
除了学术界,牛津仪器的原子力显微镜也在疫苗制造行业发挥着作用,用于疫苗的品质控制。
Researchers used AFM techniques to measure the nanoscale structure and mechanical properties of virus-like particles. The results add to our understanding of how such particles could be used as a vaccine for the hepatitis C virus.
Although infection by the hepatitis C virus (HCV) can result in chronic liver disease, cancer, and even death, no approved vaccine for it currently exists. Noninfectious, self-assembling constructs called virus-like particles (VLPs) are promising candidates for an HCV vaccine. However, more information about their biophysical, biomechanical, and biochemical properties is needed to guide research.
The sub-200 nm size of HCV VLPs makes them difficult to characterize with traditional tools such as light microscopy and X rays. Therefore, a team of researchers at RMIT University and other Australian institutes demonstrated the power of AFM to evaluate biomolecules such as VLPs.
Working with VLPs that represented four common HCV genotypes, they performed in-situ morphology imaging and nanomechanical measurements on single particles. The images revealed fine structural features such as ordered core packing and indicated significant variation in particle size. In addition, the nanomechanical measurements revealed particles had a substantial range of elastic modulus.
By improving our fundamental understanding of these nanoscale particles, the results could advance efforts to develop an effective vaccine for hepatitis C.
Cypher ES
Topography images with scan widths as small as 100 nm were acquired in a droplet of buffer solution in small-amplitude tapping mode on the Cypher ES AFM. In addition, over 100 force curves were acquired on single, intact VLPs of each type. In both cases, measurement repeatability was enhanced by the ES’s sealed cell, which minimized buffer evaporation and temperature fluctuations. The high spatial resolution, ultralow noise floor, and high force sensitivity of Cypher AFMs further ensured high measurement precision and accuracy. Built-in software for force curve analysis streamlined calculations of elastic (Young’s) modulus.
Citation: S. Collett, J. Torresi, L. Earnest-Silveira et al., Probing and pressing surfaces of hepatitis C virus-like particles. J. Colloid Interface Sci. 45, 259 (2019). https://doi.org/10.1016/j.jcis.2019.03.022
Note: The data shown here are reused under fair use from the original article, which can be accessed through the article link above.
全新体验!欢迎关注牛津仪器一站式客户互动平台
快速响应,专业耐心,牛津仪器Oi Service高效助力用户平台取得成功——访北大生命科学学院公共仪器中心覃思颖
响应设备更新政策 | 2024 WITec多功能联用共聚焦拉曼系统选型指南
响应设备更新政策 | 2024 低温强磁场设备选型指南
牛津EMCCD探测器iXon Ultra 897
牛津EMCCD探测器iXon 888
日本电子JED能谱元素分析系统 AZtecTEM
透射电镜元素分析系统 牛津仪器能谱仪Xplore TEM
透射电镜元素分析系统 牛津仪器能谱仪UltimMax TLE
透射电镜元素分析系统 牛津仪器能谱仪UltimMax TEM
台式共聚焦显微镜BC43牛津仪器ANDOR
牛津仪器原子力显微镜 Cypher VRS1250
扫描电镜微量元素分析系统 牛津仪器波谱仪AZtecWave
Sona sCMOS 生命科学显微相机平台
用于天文学和物理科学的超灵敏背照式sCMOS相机
波长色散谱仪
电镜专用微区结构分析---牛津仪器全能型 S2 EBSD
牛津仪器Proteox5mK 稀释制冷机
牛津仪器快速扫描电容显微镜(SCM)
