Analysis of 200+ Pesticides at 500 SRMs/s using a Non-Timed SRM MS Method and a Short LC Method on TSQ Endura MS
2015/02/16   下载量: 15
方案下载
应用领域
检测样本
检测项目
参考标准
The TSQ Endura MS can perform screening and quantitation of 224 pesticides with 500 SRMs in peach matrix using a non-timed SRM MS method and a short LC run (<10 minutes) The ultra fast data acquisition rate of 500 SRM/s allowed us to improve productivity: significantly simplified method development, especially for large compound lists eliminate the need to set up a specific time windows for each compound Accommodate shifting retention times in different matrices shorten LC run time
方案下载
下一篇 EPA Draft Method 543 Quantitation of Organic Pesticides in Drinking Water Using Online Pre-concentration/Solid Phase Extraction and Tandem Mass Spectrometry
文献贡献者
相关方案
当前位置: 赛默飞色谱与质谱 方案 Analysis of 200+ Pesticides at 500 SRMs/s using a Non-Timed SRM MS Method and a Short LC Method on TSQ Endura MS
