离子色谱法(安培检测器)测定血清、尿及头发中微量碘
2017/11/18   下载量: 2
方案下载
应用领域 医疗/卫生
检测样本 其他
检测项目
参考标准 ·
his paper intreduces a reasonable pretreatment method for IC-amperometric method employed to measuretrace amount of iodine in serum, urine and hair. The resultant graph is simple and clear,and withoutinterference in a general way. The limits of detection for iodine in serum,urine and hair are 0.007,0.003μg/mL and 0. 046μg/g, respectively.The recovery of iodine added into the sample is 82~93%. The coefficient ofvariation is less than 9%. Trace amount of bromine in the sample can also be measured simultan 戴安仪器:DX120
方案下载
配置单
下一篇 赛默飞色谱与质谱:尿中微量碘检测
文献贡献者
相关方案
当前位置: 赛默飞色谱与质谱 方案 离子色谱法(安培检测器)测定血清、尿及头发中微量碘
