GC-ECD大体积进样分析水和土壤中多氯联苯
2018/04/25   下载量: 2
方案下载
应用领域 环保
检测样本 土壤
检测项目 有机污染物>多氯联苯/氯苯类化合物
参考标准 GC-ECD
A 20-30 times more sensitive method than traditional GC- ECD has been developed and validated for the determination of PCBs in soil and water. Methods of analysis were evaluated through determination of detection limits (down to sub ppb level), quanti?cation limits (down to few ppb), linearity and repeatability. Validation was completed by the determination of PCBs extraction recoveries obtained using Liquid/Liquid and ASE extraction. LV-SL has proven to be a reliable tool for trace analysis in environmental applications, being robust against “very dirty” samples like soil extracts. LV-SL is theeasiest large volume injection GC technique, since it doesnot require any special hardware or tedious tuning of operating parameters. Full automation is provided through the dedicated LV-SL Assistant software.
方案下载
配置单
方案详情
Environmental legislations approved by federal agencies
like US EPA, or by European Commission Directives [1,2],
aim at the most severe reduction of the PCB levels in
water and soils (< 1 ng/kg in the original sample). This
implies, for a PCB analytical method to be validated, the
achievement of very low detection limits (< 0.5 ng/kg in
the extract).
The identification and quantitation of PCBs is most
often accomplished by gas chromatographic techniques
coupled with Electron Capture Detector (ECD), which has
selective sensitivity to chlorinated compounds. Method
sensitivity can be further amplified using large sample
volume injection into the GC [3]. Among the different
techniques used for large volume injection, the recently
introduced LV-SL [4] has the following advantages: (1) It
is simpler because it allows injections, up to 50 µL, in a
conventional split/splitless injector without any special
tuning of operating parameters, and (2) it is robust when
analyzing sample by-products or contaminants, such as
those found in food matrices or soil extracts. It is also
suitable for the analysis of labile pesticides, and it is
compatible with any GC detector [5].
In this method, the application of Large Volume
Splitless (LV-SL) to GC-ECD is validated for the
determination of polychlorinated biphenyls (PCBs) in soil
and water samples.  GC-ECD analyses of 20-30 µL of (1)
standard Aroclor mixtures and (2) Liquid/Liquid or
Accelerated Solvent Extraction (ASE) extracts of spiked
water/soil matrices are reported. Injections were
performed with the TriPlus Autosampler; GC oven, and
conventional SSL injector conditions were set-up with
dedicated software; the analytical method was validated
through determination of detection limits, linearity,
extraction recoveries, and repeatability.
detection limits (down to sub ppb level), quantification
ASE extraction.
下一篇 高分辨双聚焦磁式质谱仪环境领域应用指南
文献贡献者
相关方案
当前位置: 赛默飞色谱与质谱 方案 GC-ECD大体积进样分析水和土壤中多氯联苯
