EPA方法525.2:AutoTrace 280固相萃取水中Malathion
2019/12/18   下载量: 1
方案下载
应用领域 环保
检测样本 环境水(除海水)
检测项目
参考标准 0
The Dionex AutoTrace 280 instrument with the cartridge configuration provides an automated, solidphase extraction system that replaces traditional liquid-liquid extraction. Results show that using the cartridge configuration gives excellent recovery and precision results.
方案下载
配置单
方案详情
Traditionally, semivolatiles in drinking water have been extracted using liquid-liquid extraction techniques such as separatory funnel or continuous liquid-liquid extraction. While these techniques are effective, they use large volumes of organic solvent (up to 300 mL per sample) and require extensive user intervention or monitoring.
Solid-phase extraction (SPE) is an alternative accepted extraction technique for USEPA Method 525.2 which uses significantly less solvent (up to 60 mL per sample).
The Thermo Scientific Dionex AutoTrace 280 extraction instument offers an automated SPE technique that saves solvent and time, and decreases user intervention thanks
to automation.
With the Dionex AutoTrace 280™ system, the compounds of interest are trapped on SPE adsorbents, then eluted with liquid solvents to generate an extract that is ready for analysis. The Dionex AutoTrace 280 system saves time, solvent, and labor ensuring high reproducibility and productivity for analytical laboratories. The unit can process up to six samples with minimal operator involvement. The Dionex AutoTrace 280 system uses powerful pumps (no check valves) and a proven positivepressure technology to efficiently process liquid samples.
Current analytical methods that may require SPE sample preparation include GC, GC-MS, LC, and LC-MS. This work describes the use of the Dionex AutoTrace 280 instrument for extraction of semivolatile organic compounds from water samples.
下一篇 EPA方法525.2:AutoTrace 280固相萃取水中Bromacil
文献贡献者
相关方案
当前位置: 赛默飞色谱与质谱 方案 EPA方法525.2:AutoTrace 280固相萃取水中Malathion
