方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Battery thermal management is critical for high-power battery packs commonly used in electric vehicles (EV) and hybrid electric vehicles (HEV). To design battery thermal management systems properly, obtaining accurate heat generation data from battery modules is essential. To measure heat generation from full-size, multiple-cell battery modules, we developed and tested a custom-made calorimeter for large modules. Battery modules with dimensions up to 21 cm x 39 cm in cross section and 20 cm in height can be placed in the cavity of the calorimeter for measuring heat generation rates from 1 W to 100 W with the battery operating at -30(C to +60(C. The instrument is capable of measuring heat effects as small as 10 joules with accuracy of 5%. A state-of-the-art high power battery cycler is used to cycle the modules in the calorimeter. This paper provides a description of the calorimeter, calibration test results on its performance, and test results from a module simulating a HEV lead-acid battery.
绿茶中咖啡因的超临界二氧化碳
香港环球分析:超临界二氧化碳萃取橘皮中黄酮类化合物的工艺研究
香港环球分析:顶空固相微萃取气质联用测定蒜油的挥发性成分
