资料下载The recently developed differential fast scanning calorimetry (DFSC) is used for a new look atthe crystal growth of poly(-caprolactone) (PCL) from 185 K, below the glass transition temperature, to 330K, close to the equilibrium melting temperature. The DFSC allows temperature control of the sample and determination of its heat capacity using heating rates from 50 to 50,000 K/s. The crystal nucleation and crystallization halftimes were determined simultaneously. The obtained halftimes cover a range from 310-2 s (nucleation at 215 K) to 3109 s (crystallization at 185 K). After attempting to analyze the experiments with the classical nucleation and growth model, developed for systems consisting of small molecules, a new methodology is described which addresses the specific problems of crystallization of flexible linear macromolecules. The key problems which are attempted to be resolved concern the differences between the structures of the various entities identified and their specific role in the mechanism of growth. The structures range from configurations having practicallyunmeasurable latent heats of ordering (nuclei) to being clearly-recognizable, ordered species withrather sharp disordering endotherms in the temperature range from the glass transition to equilibrium melting for increasingly perfect and larger crystals. The mechanisms and kinetics of growth involve also a detailed understanding of the interaction with the surrounding rigid amorphous fraction (RAF) in dependence of crystal size and perfection.
遵循欧洲药典进行称量,确保符合章节 2.1.7 的要求
简介:本白皮书介绍欧洲药典通则 2.1.7“分析用天平”中的称量要求。按照欧洲药典要求,工作时必须遵守该章节内规定的校准、性能检查和生命周期管理要求。
称量仪器的校准,确保在安全范围内称量
简介:在此白皮书中,您将了解到校准、调整与检定的区别,EURAMET cg-18 所执行的校准步骤,以及关于最小称量和安全称量范围的相关内容。
RapidCal™ 料罐称校准,快速获得稳定质量
简介:在此白皮书中,您将了解到下述话题:为什么罐秤校准如此重要?什么是 RapidCal™ 以及工作原理?与传统罐秤校准方法的比较以及对生产与质量的益处。
实验室天平测试指南
简介:了解如何对实验室天平正确进行日常测试。在计划内校准间隔期对实验室天平或秤进行日常测试有助于确保及早检测到不符合称量过程要求的情况,以便于及时采取纠正措施,从而保持准确性。
梅特勒托利多过程分析产品校准服务
简介:在此白皮书中,您不仅将了解到如何通过电导率传感器、模拟和数字变送器及臭氧传感器等过程分析产品的校准服务,实现高性能测量,保持精确度和合规性。
