方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The recently introduced HAAKE MARS platform features a modular design that allows researchers to adapt the system quickly and easily for different applications and test needs. All rheological measurements can be performed in CR (controlled rate), CS (controlled stress) and CD (controlled deformation) modes, in rotation and in oscillation. A new normal force sensor allows negative normal forces to be measured for tensile test applications. The new oven is designed for ease of handling, functionality and a wide range of measurements. The oven chamber can be observed through viewing windows. The independent movement of the chamber halves promotes fast sample trimming and cleaning. The oven uses a combination of radiant and convective heating, which provides fast temperature ramps and extremely small temperature gradients. When not in use, it can quickly be parked out of the measuring area. The HAAKE MARS sytem is easy to operate, and the base frame offers room for expansion with simple adjustments to accommodate additional modules and to customize applications. All relevant components, including the measuring head and electronics, can be interchanged. The rugged frame is made from precision casting designed to increase its strength and to expand its capabilities for future measurement components. The HAAKE RheoWin 3 software and new sensor recognition tool allow measurement and evaluation functions to be performed and saved easily. In addition, an optional polymer software package allows the user to calculate master curves, spectra and molecular weight distributions. For more information about the MARS platform and Thermo Electron Corporation’s
赛默飞卫生级(Hygienic)应用双螺杆挤出机
赛默飞分子光谱技术在锂电行业解决方案
赛默飞哈克(HAAKE)旋转流变仪在皮肤外用制剂上的应用
赛默飞HAAKE™ MARS ™ iQ 旋转流变仪
全自动酸逆流清洗系统UV900
实验室玻璃器皿清洗消毒机UV 800
哈克旋转粘度计HAAKE Viscotester D
便携式流变仪HAAKE Viscotester iQ
智能化粘度计 HAAKE VT iQ
流变红外联用单元-HAAKE Rheonaut
哈克微型双螺杆挤出机PROCESS 11
多功能转矩流变仪HAAKE PolyLab OS
模块化转矩流变仪HAAKE PolyLab QC
微型双螺杆挤出机HAAKE Process 11
微量混合流变仪HAAKE MiniLab II
微量混合挤出仪HAAKE MiniCTW
微量注射成型仪HAAKE MiniJet Pro
哈克平行同向双螺杆挤出机 Eurolab16
