方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Capsaicin, and several other related compounds such as dihydrocapsaicin, are called capsaicinoids and are produced as secondary metabolites by chili peppers. Because of the burning sensation caused by capsaicin when it comes in contact with the mucous membranes of the mouth, it is frequently used in food products to give them added spice or "heat" (pungency). Capsaicin can also be found in topical lotions where it acts as a pain reliever for minor aches and pains that may be associated with backaches, strains, sprains and arthritis. The degree of heat found within a food can be measured on the Scoville scale, however high performance liquid chromatography (HPLC) is a more accurate method of calculating heat pungency resulting from capsaicin content in a food product. This poster describes the analysis of capsaicin and dihydrocapsaicin by HPLC utilizing the Breeze 2 System, a simple-to-use, modular chromatographic system. The resulting method possesses excellent area count reproducibility, retention time reproducibility, reliable quantification, and low carryover performance, demonstrating the excellent performance of this modular system. A Modular HPLC System for Routine Analysis of Capsaicin from Hot Sauces Michael Waite, Andrew Aubin, Tanya Jenkins Waters Corporation, Milford, MA, USA Fgiure 2. Breeze 2 Modular HPLC Syste
利用Xevo TQD定量测定基因毒性杂质
XBridge Premier X 色谱柱助力 SEC MALS 在治疗性蛋白药物,生物类似 药以及腺相关病毒中的分析表征
基于SYNAPT XS的全谱图分子成像系统:结合多种成像技术 获得全面分析结果
沃特世Xevo G3 QTof四极杆飞行时间质谱
沃特世Xevo TQ Absolute串联四极杆质谱仪
搭载ACQUITY Premier的BioAccord LC-MS系统
SELECT SERIES MRT
Arc Premier系统
ACQUITY Premier系统
沃特世Andrew+ Pipetting Robot自动移液机器人
DESI XS
ACQUITY APC超高效聚合物色谱系统
ACQUITY RDa质谱检测器
RADIAN ASAP直接质谱检测器
Arc HPLC系统
Prep SFC 150 AP系统
Waters Xevo TQ-S cronos三重四极杆质谱仪
SYNAPT XS高分辨率质谱仪
