方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract An analytical procedure for determination of As(Ⅲ) and As(Ⅴ) in soils using sequential extraction combined with flow injection (FI) hydride generation atomic fluorescence spectrometry (HG-AFS) was presented. The soils were sequentially extracted by water, 0.6mol/L KH2PO4 solution , 1%(v/v) HCl solution and 1%(w/v) NaOH solution . The arsenite (As(Ⅲ)) in extract was analyzed by HG-AFS in the medium of 0.1 mol/L citric acid solution , then the total arsenic in extract was determined by HG-AFS using on-line reduction of arsenate with L-cysteine . The concentration of arsenate (As(Ⅴ)) was calculated by the difference . The optimum conditions of and determination were studied in detail . The detection limit (3σ) for As(Ⅲ) and As(Ⅴ) were 0.11 and 0.07 ug/L,respectively. The relative standard deviation (R.S.D.) was 1.43%(n=11) at the 10 ug/L As level. The method was applied in the detemination of As(Ⅲ) and As(Ⅴ) of real soils and the recoveries of As(Ⅲ) and As(Ⅴ) were in the range of 89.3-118 and 80.4-111%,respectively.
北分瑞利:液氧中一氧化碳、二氧化碳杂质的分析
北分瑞利:液氧中烃类杂质的分析
WFX系列原子吸收火焰法检测 土壤中的铜、锌、铅、镍、铬
