资料下载Polyaniline ~PANI! has been studied as an active material for electrochemical capacitors. Polymerization of aniline to PANI has been carried out potentiodynamically on a stainless steel ~SS! substrate, instead of Pt-based substrates generally employed for this application. The PANI/SS electrodes have been evaluated by assembling symmetrical capacitors in NaClO4 1 HClO4 mixed electrolyte and subjecting them to galvanostatic charge/discharge cycles between 0 and 0.75 V. The effect of substrate has been assessed by comparing the capacitance of PANI/SS and PANI/Pt electrodes. The capacitance of PANI/SS electrode is higher than that of PANI/Pt electrode by several times. The effect of sweep rate of potentiodynamic deposition of PANI/SS on capacitance has been investigated. At a power density of 0.5 kW kg21, a capacitance value of 815 F g21 of PANI is obtained for the deposition sweep rate of 200 mV s21. Increase in thickness of PANI on the SS substrate results in an increase in capacitance of PANI. This value of capacitance is the highest ever reported for any electrochemical capacitor material. Thus, in addition to a favorable economic aspect involved in using SS instead of Pt or Pt-based substrate, the advantage of higher capacitance of PANI has also been achieved.
瑞士万通OMNIS奥秘一代全新电位滴定平台
简介:瑞士万通OMNIS奥秘一代全新电位滴定平台 包含OMNIS详细的主要功能和特点 以及各种仪器参数等等
瑞士万通ECO 离子色谱系统
简介:简单 经济 耐用 ?智能型离子色谱系统 ?操作便捷,性能稳定 ?测定结果准确可靠 ?测定各种样品中的阴离子、阳离子及其它极性物质
瑞士万通电化学工作站应用报告
简介:腐蚀的基本概念--腐蚀主要就是金属的退化和钝化,最主要的一个例子就是钢中贴的腐蚀,大部分腐蚀属于电化学反应......
卡尔费休库仑法测丁酮的水分
简介:加100mL无隔膜库仑法醛酮试剂于滴定杯中,并滴定至无水(预滴定)。用注射器加入样品适量,测定水分。测定酮类样品的水分,要使用库仑法醛酮专用试剂
瑞士万通库仑法测定化工产品中的水分
简介:应用领域 化工行业 关键词 库仑法;899;化工产品;水分 摘要 采用899 库仑水分仪测定化工产品中的水 分 样品 吡啶类物质,白色粉末状,溶于乙腈、甲醇、 甲苯等有机溶剂。
瑞士万通通心服务 Metrohm Service Agreement
离子色谱--925 CN 离子色谱仪 瑞士万通
手持拉曼光谱仪-1064nm手持式拉曼光谱仪 TacticID® Mobile
瑞士万通TacticID-1064手持式危化品,成瘾性物质快速鉴定拉曼光谱仪
瑞士万通i-Raman Prime高通量高深致冷便携型拉曼光谱仪
手持拉曼光谱仪-全新MIRA XTR 手持式拉曼光谱仪 瑞士万通
瑞士万通VIONIC 威欧全新电化学工作站
瑞士万通DS2500 近红外光谱液体分析仪
瑞士万通电化学近红外光谱仪
瑞士万通μStat-i 400(s)恒电位仪/阻抗分析仪
瑞士万通Eco KF容量法卡尔费休水分测定仪
Misa:食品安全检测表面增强拉曼技术解决方案
瑞士万通2060在线离子色谱过程分析仪
PILS-IC飘视TM空气样品液化器-离子色谱联用系统
瑞士万通2060 过程分析仪
