资料下载Results are reported of experiments and modelling of cathodic Pb and anodic PbO2 electrodeposition, aimed at developing a process using both reactions simultaneously for treating aqueous effluents from lead-acid battery plants. Pb(II) solubilities and equilibrium potentials were calculated as functions of pH and sulfate activities. Using kinetic parameters from the literature or determined experimentally, (illustrative) models were developed for current density-potential and current efficiency-potential relationships, together with the current density dependence of specific electrical energy consumptions for Pb(II) recovery. Experimental current density-potential and charge efficiency-potential relationships were in broad agreement with model predictions, with near unity current efficiencies for mass transport controlled PbO2 deposition from electrolytes containing 1 mol Pb(II) m-3 at pH 0.7 or 12. However, charge efficiencies for cathodic deposition of lead were typically 0.2 for 1 mol Pb(II) m-3 + 1 mol O2 (aq) m-3; removal of dissolved oxygen was predicted and determined to increase current efficiencies to near unity. Simultaneous cathodic Pb and anodic PbO2 electrodeposition was predicted to be feasible, with tight control of current densities being required to minimise specific electrical energy consumptions.
瑞士万通OMNIS奥秘一代全新电位滴定平台
简介:瑞士万通OMNIS奥秘一代全新电位滴定平台 包含OMNIS详细的主要功能和特点 以及各种仪器参数等等
瑞士万通ECO 离子色谱系统
简介:简单 经济 耐用 ?智能型离子色谱系统 ?操作便捷,性能稳定 ?测定结果准确可靠 ?测定各种样品中的阴离子、阳离子及其它极性物质
瑞士万通电化学工作站应用报告
简介:腐蚀的基本概念--腐蚀主要就是金属的退化和钝化,最主要的一个例子就是钢中贴的腐蚀,大部分腐蚀属于电化学反应......
卡尔费休库仑法测丁酮的水分
简介:加100mL无隔膜库仑法醛酮试剂于滴定杯中,并滴定至无水(预滴定)。用注射器加入样品适量,测定水分。测定酮类样品的水分,要使用库仑法醛酮专用试剂
瑞士万通库仑法测定化工产品中的水分
简介:应用领域 化工行业 关键词 库仑法;899;化工产品;水分 摘要 采用899 库仑水分仪测定化工产品中的水 分 样品 吡啶类物质,白色粉末状,溶于乙腈、甲醇、 甲苯等有机溶剂。
瑞士万通通心服务 Metrohm Service Agreement
离子色谱--925 CN 离子色谱仪 瑞士万通
手持拉曼光谱仪-1064nm手持式拉曼光谱仪 TacticID® Mobile
瑞士万通TacticID-1064手持式危化品,成瘾性物质快速鉴定拉曼光谱仪
瑞士万通i-Raman Prime高通量高深致冷便携型拉曼光谱仪
手持拉曼光谱仪-全新MIRA XTR 手持式拉曼光谱仪 瑞士万通
瑞士万通VIONIC 威欧全新电化学工作站
瑞士万通DS2500 近红外光谱液体分析仪
瑞士万通电化学近红外光谱仪
瑞士万通μStat-i 400(s)恒电位仪/阻抗分析仪
瑞士万通Eco KF容量法卡尔费休水分测定仪
Misa:食品安全检测表面增强拉曼技术解决方案
瑞士万通2060在线离子色谱过程分析仪
PILS-IC飘视TM空气样品液化器-离子色谱联用系统
瑞士万通2060 过程分析仪
