方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Corrosion refers to a process that involves deterioration or degradation of metal. The most common example of corrosion is the formation of rust on steel. Most corrosion phenomena are of electrochemical nature and consist of at least two reactions on the surface of the corroding metal. One of the reactions is the oxidation (e.g., dissolution of iron) also referred to as the anodic partial reaction.other is a reduction reaction (e.g., reduction of oxygen), and is referred to as the cathodic partial reaction. The products of the electrochemical reactions can react with each other non-electrochemically to form the final product (e.g., rust). For example, the corrosion of iron to form rust proceeds according to the overall reaction:
瑞士万通:瑞士万通应用报告-电位滴定法测定药物制剂的游离脂肪酸含量
瑞士万通:瑞士万通应用报告-电位滴定法测定药物制剂的过氧化值
瑞士万通:电位滴定法测定药物制剂的游离脂肪酸含量
瑞士万通通心服务 Metrohm Service Agreement
离子色谱--925 CN 离子色谱仪 瑞士万通
手持拉曼光谱仪-1064nm手持式拉曼光谱仪 TacticID® Mobile
瑞士万通TacticID-1064手持式危化品,成瘾性物质快速鉴定拉曼光谱仪
瑞士万通i-Raman Prime高通量高深致冷便携型拉曼光谱仪
手持拉曼光谱仪-全新MIRA XTR 手持式拉曼光谱仪 瑞士万通
瑞士万通VIONIC 威欧全新电化学工作站
瑞士万通DS2500 近红外光谱液体分析仪
瑞士万通电化学近红外光谱仪
瑞士万通μStat-i 400(s)恒电位仪/阻抗分析仪
瑞士万通Eco KF容量法卡尔费休水分测定仪
Misa:食品安全检测表面增强拉曼技术解决方案
瑞士万通2060在线离子色谱过程分析仪
PILS-IC飘视TM空气样品液化器-离子色谱联用系统
瑞士万通2060 过程分析仪
