方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
A methodology using capillary electrophoresis with tandem mass spectrometry detection (CE-MS/MS) was developed, and applied to determine the cocaine content of seized drugs. The cocaine separation among other concomitants by capillary electrophoresis was achieved in just 4.0 minutes using 30 mM ammonium formate, pH 6.5, as a background electrolyte (BGE). The correlation coefficient of the calibration curve in the range of 0.02 to 1 μg/mL was upper 0.999, and the limits of detection (LOD) and limits of quantification (LOQ) were 0.003 μg/mL and 0.01 μg/mL, respectively. The relative standard deviation repeatability (intraday and interday) was less than 6.5% (peak area). The analysis of seized suspected illegal drugs revealed the presence of cocaine in 93% of samples (n = 11), in amounts ranging from 0.04 to 429 mg/g, showing a high variability of concentrations of cocaine. The user can change the provider and, due to the large variability of concentration, be lead to an accidental overdose
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
