方案下载应用领域 | 环保 |
检测样本 | 土壤 |
检测项目 | (类)金属及其化合物>锌(Zn), 锰(Mn), 钾(K), 钠(Na), 铝(Al), 钙(Ca), 铁(Fe), 镁(Mg), 铜(Cu) |
参考标准 | - |
The elemental profile of river sediments provides valuable insight into the health of a river, as well as the wider environment. Some elements that are essential for the ecology of the river at trace levels e.g. manganese, copper and zinc, can be toxic at high concentrations. Traditionally, the concentration of elements in river sedi ments is determined via Flame Atomic Absorption Spectroscopy (FAAS). This technique has the drawback of requiring expensive and hazardous gases such as acetylene and nitrous oxide and also requires element - specific sample preparation that adds time and cost to the analysis. The novel Agilent 4200 Microwave Plasma - Atomic Emission Spectrometer (MP - AES) is the ideal alternative for laboratories looking to transition away from FAAS to a higher performance, lower cost and safer technique. MP - AES is a fast sequential, multielement analytical technique that uses a microwave - induced nitrogen - based plasma for sample excitation. The use of nitrogen eliminates the need for acetylene and nitrous oxide, which can
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
