方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
ASTM 2668 and IEC 60666 are the standard test methods, using infrared spectroscopy (IR) technology to monitor the concentrations of DBPC and DBP in electrical insulating oil. These test methods are used to determine if the new electrical insulating oil meets the specification for oxidation inhibitor initial concentration levels. They also monitor the concentration of inhibitors in the used oil. If the inhibitors have been depleted to a critical level, additional inhibitor can be added. Therefore, the standard test methods are essential for manufacturing control, specification acceptance, and to periodically monitor the level of inhibitors in used oils.
The phenolic antioxidants 2,6-ditertiary-butyl paracresol (DBPC) (also known as butylated hydroxytoluene (BHT)) and 2,6-ditertiary-butyl phenol (DBP) are the two most common oxidation inhibitors added to the electrical insulating (transformer) oil and mineral oil based lubricants. The typical recommended value of DBPC and DBP in fresh electrical insulating oil is approximately 0.3% by weight. These inhibitors prevent electrical insulating oil from oxidative degradation, and prolong the life of the oil. It is essential to maintain the optimum concentration level of inhibitors to ensure the proper functioning of mineral oil used in transformer units as an insulating or cooling agent. The depletion rate of the inhibitors in the oil is dependent on various factors such as the amount of oxygen available, soluble contaminants, catalytic agents, and temperature. Therefore, regular testing of the inhibitors in electrical insulating oil is necessary to ensure its reliable operation in high value assets such as transformer units. ASTM 2668 and IEC 60666 are the standard test methods, using infrared spectroscopy (IR) technology to monitor the concentrations of DBPC and DBP in electrical insulating oil. These test methods are used to determine if the new electrical insulating oil meets the specification for oxidation inhibitor initial concentration levels. They also monitor the concentration of inhibitors in the used oil. If the inhibitors have been depleted to a critical level, additional inhibitor can be added. Therefore, the standard test methods are essential for manufacturing control, specification acceptance, and to periodically monitor the level of inhibitors in used oils.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
