方案下载应用领域 | 环保 |
检测样本 | 固体废物 |
检测项目 | (类)金属及其化合物>锌(Zn), 锰(Mn), 铬(Cr), 钙(Ca), 铁(Fe), 镁(Mg), 铜(Cu) |
参考标准 | - |
Managing the treatment and disposal of domestic sludge is an important activity and one that is highly regulated in many countries. After treatment, the effluent may be discharged leaving a mixture of water, organic solids and chemicals, nutrients, heavy metals, and inorganic ions. This sludge can be further treated and the resulting biosolids can then be applied to the land as a fertilizer, sent to landfill or incinerated. It is vital that the sludge or biosolids are tested and conform to regulatory levels in order to protect public health and the environment. The United States federal biosolids rule is contained in 40 CFR Part 503. The European Union Sludge Directive 86/278/EEC is expected to be revised as several Member States have enacted and implemented stricter limit values for heavy metals and set requirements for other contaminants. In this work, an Agilent 4200 MP - AES was used to deter mine major and minor elements in domestic sludge, following microwave digestion.
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
