方案下载应用领域 | 制药 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
Pyrrolizidine alkaloids (PAs) and their N - oxides (PANOs) have serious hepatotoxic effects in both humans and animals, necessitating a method capable of detecting, characterizing, and quantifying them using a robust assay. While triple quadrupole LC/MS systems are ideal for targeted detection, targeted analysis requires standards that are not always easily obtained. Only a fraction of known naturally occurring PAs are available as standards. Triple quadrupole analyses are also not useful for screening unknowns. High - res olution mass spectrometers that provide accurate - mass data enable characterization of unknown PAs/PANOs without the need for specific standards. This application note presents a workflow that uses accurate - mass Q - TOF LC/MS, with All Ions MS/MS and databas e/mass spectral library searching, for the selective and sensitive characterization, screening, tentative identification, and quantification of PAs and PANOs in botanicals and dietary supplements. Twenty - five PA/PANO standards were characterized using their high - resolution accurate - mass MS/MS spectra. These data were used to create a personal com - pound database and library (PCDL) that was then used to screen for PAs/PANOs in 44 botanical and dietary supplement samples. Quantitation was performed using Q - TOF LC/MS response. PAs/PANOs not specifically targeted were tentatively identified using characteristic fragment ions and fragmentation patterns. The PAs/PANOs characterized could potentially lead to the discovery of more unique PAs in additional botan ical and dietary supplement sample s.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
