方案下载应用领域 | 食品/农产品 |
检测样本 | 其他食品 |
检测项目 | 过敏原>其他 |
参考标准 | - |
The presence of hidden nut and tree nut allergens in foods can result in serious health issues, necessitating a method capable of detecting and quantifying them at trace levels using a single robust assay. To find specific peptide markers that can be used to determine the presence or absence of specific nuts in food, proteins unique to 11 tree nuts (almond, pecan, cashew, walnut, hazelnut, pine nut, brazil nut, macadamia nut, pine nut, chestnut, and coconut) and peanut were enzymatically digested and analyzed using accurate - mass Q - TOF LC/MS. Each marker peptide was selected by establish ing its presence in raw and roasted nuts, processed and unprocessed food, abundance (sensitivity), sequence size, and uniqueness to a specific nut. The National Center for Biotechnology Information (NCBI) nr database searches were performed to confirm pep tide identities, and to ensure that the marker peptides chosen were not present in other nuts or common food ingredients such as barley, corn, rice, soy, and wheat. Two marker peptides were selected for each tree nut, and four were selected for peanuts. An alysis of peptide digests from grains such as barley, corn, rice, quinoa, soy, and wheat did not present interfer - ences. The peptide markers were tested to determine if they could be used to screen common foods for the presence of the 11 tree nuts and pea nut at sub - ppm levels. Foods containing nuts as listed on the label showed a response for the cor - rect nut. Foods processed using equipment also used to process other tree nuts or peanuts were in certain cases found to contain these other nuts.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
