方案下载应用领域 | 制药 |
检测样本 | 其他 |
检测项目 | 溶出物 |
参考标准 | - |
The analysis of extractable and leachable (E&L) compounds presents challenges for data interpretation and compound identification. The interpretation of data for controls and samples is traditionally performed manually, and can be very time-consuming.
The analysis of extractable and leachable (E&L) compounds presents challenges for data interpretation and compound identification. The interpretation of data for controls and samples is traditionally performed manually, and can be very time-consuming. Software-based data interpretation greatly alleviates this challenge. Mass Profiler Professional (MPP), a chemometric software application, performs differential analysis, and provides a means to readily visualize the
distribution of compounds across samples.
The identification of compounds encountered during E&L analysis using GC/MS with electron ionization (EI) requires a degree of specialized knowledge. The use of EI often results in a mass spectrum that does not contain a distinct molecular ion, and identification is dependent on matching characteristic fragmentation patterns. In E&L studies, fragmentation matching scores can be relatively poor, where compounds are present in minor concentrations or interfered by strong chemical background noise. Therefore, not all compounds may be identified unequivocally based on their fragmentation pattern alone. In this study, an Ophthalmic Drug Product (ODP) and its container closure system were analyzed using an accurate mass high resolution Agilent 7200 GC/Q-TOF system in both EI and chemical ionization (CI) modes.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
