通过微波等离子体原子发射光谱仪直接分析乙醇燃料中的 V
2017/12/18   下载量: 3
方案下载
应用领域 能源/新能源
检测样本 太阳能
检测项目
参考标准 -
A simple dilute-and-shoot procedure for determination of Cr, Ni, Pb and V in ethanol fuel by Microwave Plasma-Atomic Emission Spectrometry (MP-AES) is proposed. Samples were easily prepared and neither special nor expensive gases were needed for performing analyses. All limits of detection from 0.3–40 μg/L were compatible with the requirements taken into account when considering fuel impacts on environment and engine performance.
方案下载
配置单
方案详情
A simple dilute-and-shoot procedure for determination of Cr, Ni, Pb and V in ethanol fuel by Microwave Plasma-Atomic Emission Spectrometry (MP-AES) is proposed. Samples were easily prepared and neither special nor expensive gases were needed for performing analyses. All limits of detection from 0.3–40 µg/L were compatible with the requirements taken into account when considering fuel impacts on environment and engine performance.
上一篇 使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
下一篇 通过微波等离子体原子发射光谱仪直接分析乙醇燃料中的Pb
文献贡献者
相关方案
当前位置: 安捷伦 方案 通过微波等离子体原子发射光谱仪直接分析乙醇燃料中的 V
