方案下载应用领域 | 环保 |
检测样本 | 废气 |
检测项目 | 分子态无机污染物>其它 |
参考标准 | - |
Hydride gases, such as phosphine and arsine, are important contaminants in process chemicals used in both the petrochemical and semiconductor industries. For example, the presence of phosphine, arsine, hydrogen sulfide and carbonyl sulfide in polymer grade ethylene or propylene can have a deleterious effect on catalysts used in the production of polypropylene plastics. Accurate data on the concentrations of these contaminants at trace levels enables prediction of catalyst lifetime and minimizes production downtime.In the semiconductor industry, phosphine is used as a precursor for the deposition of group III-V compound semiconductors, and as a dopant in the manufacturing of semiconductor devices, such as diodes and transistors. In the case of group III-V compound materials, such as indium phosphide (InP), absence of other hydride dopant impurities e.g., silane, germane or hydrogen sulfide (and moisture) is critical, as they can have a profound effect on the performance of the final device. In particular, incorporated sulfur from hydrogen sulfide and carbonyl sulfide may affect the electrical properties of
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
