方案下载应用领域 | 能源/新能源 |
检测样本 | 太阳能 |
检测项目 | |
参考标准 | - |
Fossil fuels have been the main source of energy in industrial applications and transportation for decades. However, depleting reserves, environmental concerns and economic issues have led to the development of renewable, cheaper and cleaner alternatives. Bio-ethanol is one of those alternatives and is derived by fermenting the sugar and starch components of plant byproducts. Different purities of bio-ethanol are used as fuel sources. Hydrated ethanol fuel has not had treatment to remove moisture and contains between 93-96% ethanol. It is often used in flexible (flex-fuel) or dual fuel engines. Anhydrous ethanol has been treated to remove moisture and has a purity of at least 99%. It is blended at up to 25% v/v with gasoline. High purity fuel can be contaminated with elemental impurities during production, stockpiling and transportation, so accurate quantitation of metal content is important. According to ASTM D4806 specification [1] and the Brazilian National Agency of Petroleum, Natural Gas and Biofuels 2 (ANP) Resolution number 19/2015 [2], the presence of Cu, Fe, Na and S in ethanol must be controlled. Limit concentrations for Cu are 0.1 and 0.07 mg/kg (ASTM and ANP respectively), 5 mg/kg Fe (ANP), 2 mg/kg Na (ANP), and 30 mg/kg S (ASTM). In this study, the accuracy, precision and long term stability performance of the Agilent 5100 Synchronous Vertical Dual View (SVDV) ICP-OES was evaluated for the determination of Cu, Fe, Na and S in ethanol fuel samples according to ASTM D4806 and ANP Resolution 19/2015 methods.
使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
