使用 5100 SVDV ICP-OES 对地质样品中的Co金属进行超快速测定
2017/12/20   下载量: 2
方案下载
应用领域 地矿
检测样本 金属矿产
检测项目
参考标准 -
Traditionally, geological samples are analyzed using flame atomic absorption (FAAS) and/or radial ICP-OES with a vertical torch. Achieving high sample throughput at a low cost per analysis for geochemical samples can be challenging when using these techniques. The samples often have a wide range of element concentrations, requiring multiple dilutions, particularly when using FAAS. The samples also have high levels of total dissolved solids (TDS), which requires frequent cleaning of the sample introduction system. In this application note, the Agilent 5100 Synchronous Vertical Dual View (SVDV) ICP-OES was used to analyze geochemical samples containing up to 2.5% TDS. As well as demonstrating the accuracy and flexibility of the instrument, the sample measurement rate and argon consumption per sample were determined.
方案下载
上一篇 使用 Agilent 5800 ICP-OES 测定固态 电解质锂镧锆钽氧 (LLZTO) 中的 主量元素
下一篇 使用 5100 SVDV ICP-OES 对地质样品中的碱金属Ca进行超快速测定
文献贡献者
相关方案
当前位置: 安捷伦 方案 使用 5100 SVDV ICP-OES 对地质样品中的Co金属进行超快速测定
