方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
?This Application Note demonstrates: • Configuration of the Agilent 1200 Series Rapid Resolution LC (RRLC)analytical scale (AS) purification system. • Use of the Agilent 1200 Series RRLC AS purification system with anoptimized method for purification of peptide nucleic acids from solidphase synthesis.
This Application Note demonstrates the use of the Agilent 1200 Series Rapid Resolution LC analytical scale purification system for the purification of PNAs from solid-phase synthesis. For longer PNAs (~20-mer), an easier and faster purification is achieved by purifying the “Fmoc-on” product. The same HPLC method can also be used for dye-labeled PNAs. The desired products can be isolated from the crude mixture in high purity by an automated purification process that is triggered by a UV signal. The purity of the isolated PNA can be confirmed by reanalysis of the fraction.
The Agilent 1200 Series RRLC allows for fully automated purification of Fmoc-protected and fluorescence-labeled PNAs within 4 minutes, including washing and equilibration of the column. With an additional alternating column regeneration, purification of a PNA will only take 2.5 minutes per sample. As the spectra indicate, even shorter purification times can be established by using steeper gradients, thereby diminishing the overall purification time for high-throughput applications.
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
